Hellstra
    Hellstra
    I'm getting totally sick of them. I didn't choose them, I'm forced to use them because I can't get anything else in the area. Reliability just doesn't exist with their mobile service. It's driving me mad. In fact, it's a miracle I managed to post this.
    Their gateway (they force you to use theirs) is glitchy and runs very hot. The signal strength lights often stay on even when the signal drops out, while inside there's a hot-running chip with a small aluminium heatsink inside a small plastic enclosure with no fan. Whoever built the thing knows NOTHING about thermal engineering. This is why I call them Hellstra. Hellstra
    Bad caps _could_ be part of the problem, but it never really worked in the first place. I'm inclined to go "to heck with the warranty", but my Mum won't let me. This is the SECOND gateway, BTW; I blew up the first one early last year out of frustration.
    I got a Connectland HDD cooler for free with two 50mm slimline fans. Would you suggest using one of them to cool the thing down???
    Or would you suggest installing it in a different case???
    I don't really care if all I can do involves voiding the warranty. I guess they kept shrinking the heatsink until it wouldn't work, then upsized it just enough to make the thing barely work at a room temperature of 20C.
    Re: Hellstra
    By Hellstra you mean Telstra right? Where are you located in Australia?
      Re: Hellstra
      Yes.
      Albany, WA
      EDIT: Also, I didn't opt for mobile either; again, I was forced to use it.
        Re: Hellstra
        Reminds me of AT&T here
        Who makes the Gateway? is it a 2Wire?
          Re: Hellstra
          It's not a 2Wire. All it says is "Bigpond Elite Network Gateway". It's not really Elite, as I explained above.
            Re: Hellstra
            It looks like the problem may be caused by missing caps, rather than bad caps. The only electrolytic in the unit is a Chemi-con KY on the input. This leads to a relatively normal two-phase VRM with ferrite chokes. But I can't find the output capacitors.
            Later on I might try jamming something in there and tell you how it goes. It's a miracle that the thing works at all.
              Re: Hellstra
              AFIK Tel$tra modems are usually either 2Wire or Netcomm/Askey
                Re: Hellstra
                2wire stuff is fualty.
                Had my experience with the gear telstra provided me 3 years ago.
                I am happy with my service provider now, not telstra but a good isp.
                  Re: Hellstra
                  In a 2Wire AC adaptor, it had Suscon low-ESR units on the secondary side - I have seen a set-top box with bad Suscon low-ESR units (even though they were not bulging) in the power supply section.
                  Also, Telstra's (or the manufacturer's) choice of default wireless security settings is quite poor - they use a 10-digit numerical WPA passphrase, and on some other equipment, a 10-digit hexadecimal number (0-9, A-F).
                  Some manufacturers use a default WPA passphrase generated from the MAC address - another poor choice of default wireless security settings.
                    Re: Hellstra
                    Is it okay to send an email to them saying ???
                      Re: Hellstra
                      hahaha
                      have fun
