I can get it to turn on holding down power button for 30 seconds, but if turned off won't come back on. Power board is DPS- 200PP -190 and has 5v standby and 24v. I do get 385v at the long capacitors and none of the caps look bad. When it's powered I don't see any dark spots like bad backlights. Any suggestions to check next. Thanks
Vizio M651d-A2R won’t turn on
Re: Vizio M651d-A2R won't turn on
But where are the control Voltages readings?Never stop learning
Have you checked the voltages on the LED driver board? also check the fuses on that driver board. I suspect you could have a few bad (likely shorted) led's causing the led driver board to over current shut down. It only takes a couple bad leds and you likely won't see them through the lcd screen.
I haven’t been able to get it back on to test led voltage on board yet, it’s hit and miss when it decides to start up. I did order one of those led tester and get these reading with them unhooked. With the red on pin 1 and ground going down the line 2-4 I get 55.2 and the same going the other way. I will still keep trying to get it to start where I can check those while running.
1: VLED2 +
2: FB2-4
3: FB2-3
4: FB2-2
5: FB2-1
6: FB1-4
7: FB1-3
8: FB1-2
9: FB1-1
10: VLED1 +
You'll keep black probe of the meter on the chassis, put red probe on pin 1 then turn on the TV to see how high the Voltage jumps up to then wait 10 seconds to see what it goes down to, then turn off the TV and the repeat the same test on the other 9 pins.Never stop learning
I am using one of these, right now it won’t start up to test voltage. https://www.shopjimmy.com/sid-gj2c-l...ght-tester.htm
Originally posted by Hornnumb2 View PostI am using one of these, right now it won’t start up to test voltage. https://www.shopjimmy.com/sid-gj2c-l...ght-tester.htm
You are trying to test each LED sting with the LED tester.
You will pull the LED connector off the power supply board then out red robe on the connector (that goes to the LCD panel) the VLED1+, then use the black probe to test each FB1-1, FB1-2, FB1-3, FB1-4.
Do the same with LED2+and each one of the FB2-1, FB2-2, FB2-3, FB2-4.
Basically you are testing 8 LED strings.Last edited by budm; 11-23-2019, 08:01 PM.Never stop learning
unless there is some thing very "different" in the design, there is something strange with the measured results for pin 11 and 12 (BL) on cn202. Remeasure to ensure that the values are correct. Further look closely at the board / connector to see what the difference is. I would expect any "labelled point" to be the same for the same label.
Can I see the pictures off the whole backside of the TV showing all the boards?
I looks like the main board is connected directly to the LED driver board so the BL-ON and Dim controls are not routed to the power supply board.Never stop learning
You also need to do the test on post 11 using Volt meter.Never stop learning
https://assets.shopjimmy.com/media/c....d01-top_1.jpg
I cannot tell from the picture of the whole backside of the TV to see where CN1 of the LED driver board go to, same for the CN5 of the LED driver board
Picture is not straight shot so it is hard to see which cable to where.
And right now you no longer get any Voltage at VLED1 +, VLED2 + when toggle TV on and off?Last edited by budm; 11-25-2019, 09:51 PM.Never stop learning
