help da0x36mbae0 rev e does not turn on
    I have this motherboard that I turn on and the ic L8 = xx heats up
    what are the 3.3v
    I press the power button and it does not heat it turns off and heats
    change the IC twice and the same thing happens
    the USB-C ammeter indicates
    19.9v
    0.080 and 0.180a
    3.3 watts
    I attach images please I need your help
    LINK IC L8=XX
    https://cdn.badcaps-static.com/pdfs/...b416ded7d7.pdf
    Re: help da0x36mbae0 rev e does not turn on
    What is the question? When Inputs and Enable are fine you need to check the load side.
    Resistance to GND at LDO3 and LX?
    FairRepair on YouTube
      thanks for your help
      Resistance to GND at LX =8.7 k
      Resistance to GND at LDO3 = 2K
        help
          These are high resistance readings, there is no short on these measured rails.
            Could be still something after a load switch. Not the first time I would challenge this. Need experience to find the possible culprit or even better with help boardview/schematics. Unfortunately it seems, there is nothing available.
              Check impedance of bios pin 8, check LDO impedance, check coil impedance.
              Theres a possibility that SIO ,PCH or IC is short.
                sorry, I had personal problems and the laptop is no longer available for repair
                  just had one with the same fault. With the one i got the short was a cap that bridged the 3.3v and the 3.3vldo togther at the tas2557 ti 8ba6971 mono amp by the pwr connector. found by injecting 3.3v at 300ma n the ldo. cheep thermal imager and iso ftw.
                  Last edited by IDislikemakingLogins; 09-29-2022, 05:02 PM. Reason: add picture of cap
                    sorry for dumb question, please elaborate what you mean by "n the ldo" ?
                    have the same issue at hand, customer installed battery connector upside down, and now the board sometimes charges until you shut down the machine. So it resets the cycle and i think the charging chain is too hot to start charging again, so the orange charging led blinks and laptop doesn't power on, untill i disconnect the battery and wait a while. Same IC L8_XX heats up and changing doesn't help, still heats up.
                      "n the ldo"
                      I think the op meant "on the ldo".
                      LDO = low drop out regulator. Takes in a higher input voltage and will lower (burn) the input voltage value to a lower one. Often, LDO will be supporting a relatively close input to output range since the burn off effect = heat.
