Hey guys I was wondering what could be causing my Samsung 7 series tv flickering it's vertical.Sometimes it will be fine for an hour then start to flicker.
samsung un50nu7100f
Re: samsung un50nu7100f
Line looks horizontal. Check the YouTube video in Update 2. https://techhometravel.com/repair-of...ge-horizontal-
if it goes good for 30 minutes, i don't think it's a shorted panel, taping isn't likely to work.Last edited by nomoresonys; 07-20-2022, 04:27 PM.
for now unplug any devices like dvd player etc, so nothing else plugged in, make sure ribbon cables from driver board to mainboard are clean and fit well, can clean with isopropyl alcohol, some use a pencil eraser, not to vigorous they can be delicate, look the cables over closely make sure there's no damage and they are aligned correctly, see if the line is on the menu too, change source, see if line stays on the next screen, It could be driver board issue, check the little capacitors on the driver board for shorts or very low ohms, don't get them confused, they are usually designated with a little C for capacitor right beside them, another thing to try is turn the backlights way down and see if the tv stays on longer.
