Machine: Asus ZenBook UX330UA-AH54 13.3"
Specifications:
-CPU: Intel Core i5 7200U
-GPU: Intel HD Graphics 620
-RAM: 8 GB DDR3
-Storage: Samsung 860 EVO M.2 SATA (500GB)
Motherboard Model Number: 60NB0CW0-MB5020
Background:
I bought this laptop for my wife in 2016. The original M.2 drive failed and so we got my wife a new laptop (figured it was time for an upgrade anyway). I wanted to keep the ZenBook as it's a really great little portable thing that weighs nothing and is great for travel (has a nice aluminum body). I replaced the M.2 drive with a new Samsung one and reinstalled Windows. Everything was going great.
However, I noticed the battery was only charging to 67%. Recalling that the laptop was getting quite old, I figured the battery could use a replacement. I ordered a replacement battery from iFixIt. The battery appears to have the same model number, voltage, and amperage as the original Asus battery. Really the only difference is that the cables are slightly too long and they had folded them and taped them together.
I replaced the battery with the one from iFixIt, reassembled the laptop, hit the power button and...nothing. No screen or backlight, no fan. I figure, okay maybe I didn't connect something - so I recheck the connections - everything is good. I swap back to the original battery - same problem.
Now I'm getting worried because the original battery worked only moments ago. I search online and find that at least three other iFixIt customers have experienced the same or similar issues with this exact laptop and battery replacement... I figure, great...either the batteries they are sending are bad in some way or we all damaged our motherboards in the same way with ESD.
Current Behavior:
If I plug in the AC adapter (original Asus charger that came with the laptop), with no battery connected, the orange charging light comes on. If I hit the power button, the white power light comes on, but nothing else happens. If I hold the power button long enough, the white power light will flash a couple times, and then come back on but the orange charging light goes out. I have to completely remove power to get the orange light back.
If I have the battery connected, I get similar behavior.
My understanding is that this PC should boot up even with no battery attached if the AC adapter is connected - yet it is not doing that.
Inspection:
I see no visibly damaged or burnt-out components. I didn't see any sparks or smell any "burnt-electronics" smell.
Troubleshooting:
I tried following along the best I could with the "Laptop battery charging circuit" post, but got a little lost along the way.
stg.jpg (attached) shows how I interpreted step one of that thread (short to ground)
I have included pictures of the board, as well as closeups of some of the areas that seem important to the power supply/charging circuit. I did find two sets of schematics on the forum (https://www.badcaps.net/forum/showth...hlight=ux330ua) and have tried clicking through them to understand what things might be involved.
I'd be happy to check any voltages or resistances between things, I just need to know which things. If you could indicate them on the pictures that would be very helpful as I don't fully know all the terms yet (but again, I do want to learn!)
Thank you for your time and patience
Specifications:
-RAM: 8 GB DDR3
Background:
Current Behavior:
Inspection:
Troubleshooting:
