RCUnlocker
    Re: RCUnlocker
    Because i read somewhere in this thread that it is disabled for 32mb, i didnt know if that includes my HP model.
      Re: RCUnlocker
      Dump 16MB chip only, and use RCU. There's no need to play with the 32MB chip. This was already mentioned several times!
      Become a Badcaps supporter
      Thanks to all supporters.​
        Re: RCUnlocker
        It was not clear for me, couldnt get a stright asnwer like yours, thanks anyway, i will try it tomorrow.
          Re: RCUnlocker
          I tried with 16MB dump, the RCunlocker didnt change anything when i compared original with the output in Hexcmp, but HPunlocker tool made some changer yet with both of them password is still there. Any suggestion?
            Re: RCUnlocker
            Upload dump here.
              Re: RCUnlocker
              Here are both of them, original dumps.
                Re: RCUnlocker
                As you can see, everything is fine, you obviously did something wrong when you tried RCU:
                  Re: RCUnlocker
                  ok i compared both of my original and your unlocked file, can you please compare them in Hexcmp.
                  they are %100 the same. how can this solve the issue like this? i also tried that and got the same result.
                    Re: RCUnlocker
                    Seems like your hexcmp is not working because your original and what vesko gave are not the same. And when I tried RCUnlocker on it, it matched what Vesko sent but was had differences compared to your original.
                      Re: RCUnlocker
                      good then i hope its the case, i will try to flash it.
                        Re: RCUnlocker
                        guys i flashed the unlocked file, the password is still there!... i have a question i read this thread
                        https://www.badcaps.net/forum/showthread.php?t=82001
                        the guy sent both original 32 and 16 to you (RethoricalCheese) and you just modified the 32MB file and sent it back the guy had positive feedback and password was gone. any explanation please!.
                          Re: RCUnlocker
                          wow finally all passwords are gone, i really thank you guys, appreciate your effort, one last question, so i know you used RCUnlocker for the 16MB dump and what did you use for the 32MB?
                          curious for next cases.
                            Re: RCUnlocker
                            Еxperience.
                              Re: RCUnlocker
                              Excellent, thanks anyway.
                                Re: RCUnlocker
                                After using RCUnlocker, you are not supposed to get an unlocked devmode anyway.. You just need to go to devmode to clear the machine. After that you will be able to log into a random account in normal mode where you must do a powerwash to unlock devmode aswell.
                                It should be all written in info screen after unlocking..
                                  Re: RCUnlocker
                                  Hello RethoricalChesse,
                                  Do you have a firmware for
                                  Acer Chromebook Spin 311 (R721T) KASUMI360
                                  The chip is Winbond W25Q128FWSP
                                  Thank you
                                    Re: RCUnlocker
                                    Hi, if i drop a 32mb file of the 850g6 laptop the program replies that it needs 16mb chip. How can i unlock the 32mb chip ?
                                      Re: RCUnlocker
                                      Getting an error using;
                                      cx_Freeze: Python error in main script
                                      Traceback (most recent call last):
                                      File "C:\Users\kaurv\AppData\Local\Programs\Python\Python37-32\lib\site-packages\cx_Freeze\initscripts\__startup__.py", line 104, in run
                                      File "C:\Users\kaurv\AppData\Local\Programs\Python\Python37-32\lib\site-packages\cx_Freeze\initscripts\Console.py", line 15, in run
                                      File "RCUnlocker.py", line 328, in <module>
                                      File "RCUnlocker.py", line 209, in displayInfoUserCred
                                      UnicodeDecodeError: 'utf-8' codec can't decode byte 0x8b in position 0: invalid start byte
                                      OK
                                        Re: RCUnlocker
                                        @maxitaxi upload 32mb locked dump here.
                                        Indeed you need to unlock 16mb with RCunlocker, it doesnt support the 32mb chip.
                                          Re: RCUnlocker
                                          Do what it says. Read the 16MB chip and use that instead of 32MB chip...
