Corsair vs650 random power off / reboot
    I have a problem with a power supply vs 650 (of those first version with the orange label) this to be clear:
    https://www.corsair.com/it/it/Catego.../CP-9020098-EU
    the power supply turns on but randomly turns off the pc
    immediately after you can turn on the PC and cross your fingers until the next shutdown / reboot.
    The 12cm fan runs well
    there are no swollen condensers, burns, brown areas
    some photos of the components inside:
    https://www.nexthardware.com/reposit...s_n.d_-61-.JPG
    https://www.nexthardware.com/reposit...s_n.d_-63-.JPG
    https://www.nexthardware.com/reposit...s_n.d_-64-.JPG
    https://www.nexthardware.com/reposit...s_n.d_-65-.JPG
    https://www.nexthardware.com/reposit...s_n.d_-67-.JPG
    https://www.nexthardware.com/reposit...s_n.d_-62-.JPG
    Can you help me in the repair? what components could i start checking inside?
    thanks in advance to who will reply
    Re: Corsair vs650 random power off / reboot
    Do you know which power supply turns off?
    Inside an ATX PSU are two supplies: the 5VSB and the main supply (3.3v 5v, 12v -12v)
      Check the solder side of the board for poor solder connetions
        I'm not very expert ... the results of this tester can be useful to the verification you asked me?
        https://imgur.com/a/EZWunk1
        Does that 5.1 value that I see on the screen have to be monitored over time or can it be taken for good now?
          VS650 has problems keeping 12V at.. 12V under load.
          Some people report it dropping to less than 11V.
          12V output capacitors are CapXon. Replaced them with rubycons. Not sure if it helped tho.
            Can you post a picture of the bottom of this board
            9 PC LCD Monitor
            6 LCD Flat Screen TV
            1 Dell Mother Board
            15 Computer Power Supply
            All of these had CAPs POOF
              The only capacitors that I see whit CapXon brand seem to be these 2 ....
              http://imgur.com/a/zhwCb9u
              did you mean that I only have to replace these 2 with equivalents but of the rubycons brand ????
              here's a pictire of the bottom of the vs650 board:
              http://imgur.com/a/LUCEmmA
              Thank you guys
                random restart,according to my experience, due to faulty pwm chip in secondary.
                https://easyload.io/f/mWXnR5ErXO/V_I...214100_680_mp4
                Just replace the sitronix ic, st92429 pin 14 or with the equivalent wt7525 pin 14
                  [SOLVED] Corsair vs650 random power off / reboot
                  after some time I can confirm that by replacing the ic with a WELTREND WT7525Y DIP-14P I solved the random reboot problems on this power supply.
                  Let's hope this one I bought will last over time.
                  Thank you all for your invaluable help
