I'm trying to do a software update on a Sony KDL-48W600B with backlights and no picture and having absolutely no luck. I can't find anything on the Sony support website that specifies the procedure. Can anyone provide a link or instructions? Thanks!
Sony KDL-48W600B software update with no picture
Re: Sony KDL-48W600B software update with no picture
You mean to tell me there's no way to output audio and video from this piece of s**t f*****g turd of a TV so I have a chance of maybe seeing the menu on another TV and updating it that way???
J***s H. C****t, I've never seen a bigger pain in the a*s pile of f*****g G*d D**n s**t in my life....there's no definitive info on the Sony e-support site how to extract the software for this model, there's no way to output the picture to another source, there's no procedure to update the software via USB when the TV won't display a picture unless it's a f*****g Android TV or you update VIA the internet, which I can't do without a working f*****g display panel. I think a case of the clap would be easier to deal with than updating this glass double dil*o a** ramming piece of monkey s**t!
F**K SONY in the mother f*****g cornh**e, and if I can't find the info I'm going to run this m****r f****r over with my F150 then have a friend toss it in the air when I yell "PULL".
What a TERRIFFIC way to ruin an otherwise f*****g pleasant Sunday.
"I don't go off that often, but when I do, it's like you lit off 7 sticks of TNT"Last edited by DXseekerMO; 02-04-2019, 12:52 AM.They call me......."threadkiller"
https://www.sony.com/electronics/sup...loads/W0011108
Don't know if you have to use remote or not, my kdl from 2009 was a no touch update, I just put in the usb and it did it, been a while, I think I put in usb and turned tv on and took about 15 minutes, think the lights went from blinking while updating to a solid amber when done.Last edited by nomoresonys; 02-04-2019, 11:43 AM.
Thanks for the reply nomoresonys. I had a look at that page last night and downloaded the update but there was no instructions on extracting the file to a USB. I tried "extract to" the thumb drive, installed the stick in to the TV, the green LED on the thumb drive flashes for a few seconds then quits and doesn't flash again, like the TV isn't reading the data on it.They call me......."threadkiller"
I think that this page from sony us provides a "method" to follow.
one thing that I found with a sharp "method" that said to use fat32 format... that didn't work. I had to use fat16/fat formatted usb.... from there it worked very much like sony and didn't care whether the existing firmware was the same version or not, upon powering up, it began loading the file that was there. You might want to try this alternative format if the other doesn't work.
Originally posted by budwich View PostI think that this page from sony us provides a "method" to follow.
one thing that I found with a sharp "method" that said to use fat32 format... that didn't work. I had to use fat16/fat formatted usb.... from there it worked very much like sony and didn't care whether the existing firmware was the same version or not, upon powering up, it began loading the file that was there. You might want to try this alternative format if the other doesn't work.They call me......."threadkiller"
one thing that I found with a sharp "method" that said to use fat32 format... that didn't work. I had to use fat16/fat formatted usb.... from there it worked very much like sony and didn't care whether the existing firmware was the same version or not, upon powering up, it began loading the file that was there. You might want to try this alternative format if the other doesn't work.Originally posted by nomoresonys View PostBoth are the same page, hit the little plus by the usb instructions and details expand.
The only problem I see is the instructions say to "follow the instructions on the screen" which I am unable to do. I still see no alternate method of updating the TV with no display. This is all that is keeping me from trying it.They call me......."threadkiller"
From this post: https://www.badcaps.net/forum/showth...777#post852777
Originally posted by jr.rivera.p View PostI found this another way to update the software in the service manual...
1. Download the SOFTWARE corresponding to your REGION and LANGUAGE from the official SONY SUPPORT page
2. Follow the instructions to save it in USB
3. With the TV off in standby... Insert USB pen drive to USB port of TV
4. Pull Out the AC plug and wait 10 second (considering the charge of AC adaptor)
5. Press and hold the side Power Key for 5 seconds and re-insert the AC plug at the same time
6. After 20-30 seconds, the LED is turn to Amber and blink
LED blinking indicates “Under SW Update”
- IMPORTANT NOTE: PLEASE DO NOT PULL OUT
- THE AC PLUG DURING THIS STATE
7. After 1-2 minutes, LED blinking will finish... press <Power> key
If everything went well you should see the SONY logo fade and then the restored imageThey call me......."threadkiller"
If that isn't bad enough theres ABSOLUTELY NO INFO on the net about a blue light....zero.
Why is it ALWAYS THESE SONY PIECES OF S**T that screw with me?Last edited by DXseekerMO; 02-04-2019, 04:56 PM.They call me......."threadkiller"
Head scratcher, did you try a different usb drive or one of the other usb inputs? sj tute here, looks like hes dealing with the same model. https://www.youtube.com/watch?v=8pNVIH-FJao
Originally posted by nomoresonys View PostHead scratcher, did you try a different usb drive or one of the other usb inputs? sj tute here, looks like hes dealing with the same model. https://www.youtube.com/watch?v=8pNVIH-FJao
I decided to get down to the buffer boards and check to see what voltage was where. Chassis ground referenced
12V is present on either side of the T-CON fuse
There's about .4 to 1.5V at the LVDS input test points on the T-CON and for the 12V supply there's 12.7v. Unfortunately.......
AVDD 17.5V test point has zero voltage
HVADD 8.8V test point has zero voltage
VCC 1.8V test point has .7mV
I'm not so sure a software update is going to fix that.Last edited by DXseekerMO; 02-04-2019, 08:36 PM.They call me......."threadkiller"
