Hello I'm struggling with this old plasma TV and its SC board, TNPA4393, I've measured the SU/SD buffers, every IGBT and transistors, gate drivers, SMD diodes, optocouplers etc, no shorts or suspecting measurings, at least with they soldered on the board.
VSUS - 187V
VDA - 75V
VE - 130V
VSET - 320V
VAD - (-149V)
16V_F
5V_F A/B
15V
All voltages are normal except for VSCN, which according to the service manual is supposed to be 145V+-4V, it is always 205V.
VSCN voltage is fixed, generated and measured from VAD as ground, even if I lower VAD to -112V("minimum" allowed by the trimpot), VSCN doesn't change.
I have a working SC board from 42PZ80LB (Full HD model) and it has the same component placing, except more transistors to handle increased power load.
I swapped between the SC boards the VSCN controllers (IC787 and IC786) and nothing changed, the 7 blink protection of VSCN and VAD is located on the A-Board.
No changes on the voltages with or without the SU/SD buffers plugged in, also the screen is completely dark always, no flashes.
IC786 is a MIP9L02 from Panasonic itself, no datasheets, VAD is generated by the same model IC(IC784).
https://www.electronica-pt.com/esque...gph11da-14476/ link to service manual (portuguese only).
VSUS - 187V
VDA - 75V
VE - 130V
VSET - 320V
VAD - (-149V)
16V_F
5V_F A/B
15V
