Samsung PS42A457P1D stuck in standby
  • Ooger
    • Jan 2014
    • 8
    • England
    Morning all,
    First post here after registering yesterday and reading loads of useful stuff, some of which I didn't really understand too much of, but its a good start.
    I think I need your expert help though.
    I've got a problem with a Samsung PS42A457 plasma which is permanenently stuck in standby. The light is on and it receives the IR commands from the remote, but it wont come out of standby.
    I've read that this is likely to be a problem with the caps, so off the back came, expecting to see some blown/bubbled/leaking capacitors.
    Sadly none found. Well. I think none found. Plenty of dust and fluff though.
    Theres one black capacitor which looks a bit suspicious on the power board. Its got a small black dot on the top, but it still looks sealed. The dot looks like marker pen though, to the untrained eye (mine).
    I've attached a photo. Can anyone give me an opinion please before I start taking the board off and removing/replacing anything?
    The caps are all made by SAMWHA and none of them seem blown, unevenly seated or leaking, apart from this one. Ive read here that "generally" theyre quite reliable - compared to some.
    Oddly, theres the burn-in test records close to this cap, and they're marked on the circuitboard with what looks like the same "pen"....helpful, not. Just makes me a bit sceptical of what I'm looking for.
    I've got a multimeter and know my way around basic electronics, but thats about it, so far.....happy to try anything though, with your patience.
    Thanks for reading.
  • smai
    • Dec 2013
    • 69
    Re: Samsung PS42A457P1D stuck in standby
    is there no power button on the TV itself? when you push it does it feel like its "clicking"
    will you upload a picture of the whole back side, i believe there is a test mode for samy plasmas procedures i think are in the stickys posted my tom66
    • mmartell
      • Oct 2013
      • 3189
      That mark on the top of the capacitor is there from the factory. FWIW it doesn't look bloated to me however caps can look ok and fail an ESR test.
      Need more pics, one of the whole back of the set and pics of each board separately.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        That 22uF cap is the supply start-up cap for the Stdby 5V supply. (small DIL-7pin chip by its side....
        Guessing its working--as its in Standby with the red-led showing....
        Does header on PSU --'PS-On' have a voltage on it?
        Does 'Vs-On' have any voltage on it?
        Normal running--the Ps-on will be '0' V and Vs-on will be around 3V
        Ps-on will be 3.4V in Standby.
        TELEFIX
        • Ooger
          • Jan 2014
          • 8
          • England
          Thanks everyone for replies so far, just caught up.
          I've got a photo of the rear of the set, all boards attached.
          I'm not at home at the moment so can't test anything else right now.
          The power button on the front is one of those touch sensitive ones - its not a button as such. Pressing it does nothing, but the light remains on.
          Theres no "clicking" coming from anywhere apart from the large transformer on the SMPS (black square, between the 3rd and 4th heatsinks). Its a very quiet clicking though (more like a tick), and couldnt be heard with the back on...
          I feared the black mark was just that....a black mark
          More to follow when I get home. I might need some advice testing voltages please - just the points to test, I can use a multimeter.
          *EDIT - picture taken with X and Y boards disconnected - there are loose ribbon cables just hanging, I know this*
            Does faint ticking persist with the X- and Y-main unplugged?
            • Ooger
              • Jan 2014
              • 8
              • England
              Yes the ticking persists without the X and Y boards
              I'm going to check the voltage and any change in voltage tonight when the power button is pressed whilst it is in standby
              Hopefully this is a good start, as well as the answers to the q's above.
              • Ooger
                • Jan 2014
                • 8
                • England
                Considering options here, and as a preemptive thought (I know, goes against the "fix it" grain) , is this a straight swap:
                http://www.ebay.co.uk/itm/Samsung-PS...item3cdaf12f0e
                I can see its not identical - but its because the ebay listing is a revision 1.01, and my SMPS is 1.1
                Just out of interest - what are the differences?
                Obviously a swap of the whole board just means my defective board may be replaced by one that is about to become defective, for the same reasons.....
                • Ooger
                  • Jan 2014
                  • 8
                  • England
                  In standby,
                  - PS-ON on the SMPS gives me 3.2V - measured from pin 1 on CN801. It fluctuates from 3.2 to 3.4.
                  - Vs-ON reads 0V - nothing at all at pin
                  - Hitting the power switch whilst measuring these does not affect the readings, they stay the same.
                  • Ooger
                    • Jan 2014
                    • 8
                    • England
                    For completeness if anyone comes back to this thread, I replaced 6 capacitors on the PSU board with uprated ones, and voila.
                    Fixed.
                    The irregular ticking was replaced with a gentle humm before it fired up.
                    Another case where the caps didnt look bad, but were.
                    Next please!
                    • Zerocool5050
                      • Apr 2014
                      • Uk
                      Any photos of after you replaced them and whitch ones you did as I have very much the same problem.
                      • satinser
                        • Oct 2012
                        • 214
                        Just come across this thread and noticed that the last question remained not answered. Just thought i would end this thread with information that might aid future reference to stuck in standby with this power supply. Had a number like this with standby led showing but with no response. If looking carefully at standby illumination it can be seen to be slightly pulsing and is invariably caused by complete degradation of CB801 (22uf 450volt). Had a number of these lately that have degraded so badly that lost their capacitance completely.
                        Hope this helps future reference to this thread.
                          Interesting that the 450V cap goes.
                          My iiyama LCD monitor was killed when the 450V cap failed on the primary. Popped the primary-side flyback transistor.
                          Replaced transistor, resistor and cap and all was well, but thought that the failure of it was an isolated incident - obviously not.
                          • RepairSak
                            • May 2016
                            • 4
                            • Greece
                            Having exactly the same problem.
                            Thank you very much "satinser" for giving details, I'll try checking-replacing the 22μF/450V cap.
                            Dear "Ooger" if possible, answer the question which 6 caps you replaced. Maybe you replaced more than the ones needed.
                            • RepairSak
                              • May 2016
                              • 4
                              • Greece
                              Indeed CB801 22μF/450V was the problem. Replaced it and all fine. Also replaced the 50V caps around the STDBY area just in case. TV repaired!!
                              • tvtimmy
                                • Mar 2015
                                • 1160
                                • usa
                                Good job!
                                  09-07-2024, 05:50 AM
                                • tvguy12012012120
                                  by tvguy12012012120
                                  02-07-2025, 05:13 PM
                                • Ukdigger
                                  Samsung UE46f5000AK Stuck on Standby
                                  by Ukdigger
                                  When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
                                  PSU number bn44-00610A L46SF_dpn
                                  1 B13v 12.4
                                  3 B13v 12.4
                                  5 Vamp 12.4
                                  7 Vamp 12.4
                                  9 GND...
                                  08-08-2024, 09:17 AM
                                • Rusenga
                                  Samsung UA39EH5003R Stuck on standby
                                  by Rusenga
                                  Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                  Connector CNM803:
                                  TV ON
                                  Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                  TV OFF
                                  Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                  09-18-2021, 11:51 AM
                                • ChristianBr01
                                  LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                  by ChristianBr01
                                  I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                  The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                  What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                  04-23-2025, 01:48 AM
