#1 |
City & State: phx az
My Country: usa
![]() I have a couple of sony oleds that will work for a bit then shut down and start blinking red 4 times on the bottom. These tvs have thin lines that are probably shorting the panel.
Any fixs Thanks Gregg xbr65a1e xbr65a9f xbr65a8f |
#2 |
City & State: SA
My Country: Germany
![]() could you show us here photo of one of them with this thin line ?
you can located it on the ribbon if its on No 1.2.3 or 4 and with tape hide the suspected line by measure how many line at each ribbon X4 and measure the distance of the line location on the nearest side of screen to know which line or at least with couple of line... then check if the set keep on with black line on screen |
#3 | |
My Country: usa
![]() Quote:
I understand that the lines probably can't be fixed as it is in the panel but it would be nice if the tv tv could stay on..Has anyone ever successfully repaired the four blinking red lights on an oled sony thanks Gregg |
#4 |
City & State: SA
My Country: Germany
![]() you need to do good visual inspection for both of any transport damage . the panel are LG brand and which serial No.?
one last things to test those sets its always recommend with Video via HDMI or USB pen, or via live TV over Tuner. not to use still picture |
#5 |
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
![]() I suspect you will find that the thin lines are causing something to overheat which means the T-con will shut down.
I guess you could see what is overheating (a thermal camera helps, but if not, you may be able to use freezer spray carefully applied), and as a temporary fix, may be able to heat-sink it sufficiently such that it stays cool and continues operating. A likely guess will be a DC-DC converter on the T-con board. It is unlikely to be on the power supply. However I would never consider this a long term fix because if this fault is causing something to overheat, it is very likely that the driver chip that has the short present will also fail in short order, leading to a large black bar, more coloured lines or total panel failure. Last edited by tom66; 05-09-2019 at 12:01 PM.. |
#6 |
City & State: SA
My Country: Germany
![]() well i agree with tom about heating. any overload will cause it. but we need to think there are SOS signal come out from panel self. if we hide it then later we can deal with heat issue. since we don't know which OLED screen serial on this set cant say where are the SOS signal pins but its almost the last 3 pins of the last ribbon. left side or right side, easy to try hide them one side by other with thin tape from T_CON driver side and check what will going on.. this will never harm the set at all.
#7 | |
City & State: New York, NY
![]() Quote:
I've also replaced the t-con board with no success. I can trigger a t-con error, 5 red blinks, by removing the flex cables from the main board to the t-con board. I assume if there is a real t-con error, I the circuit would trigger 5 red blinks before triggering 4 red blinks. Given that the real error is 4 red blinks, I think there's a short in the panel board. Have you ever taken apart the panel to see if there are any circuits to repair? There are a few accessible capacitors on the panel next to the flex cables but I see no way to explore further without destroying the panel or cutting into it with a rotary tool. Last edited by j3scott; 07-13-2021 at 05:35 PM.. |
Thread Tools | |
Display Modes | |
