This one has a burned tab and I was wondering if I could just remove the defective tab to fix the issue. Any suggestions would be appreciated.
Samsung UN50MU6300 burnt tab bond
Re: Samsung UN50MU6300 burnt tab bond
Nothing you can do, as I'm fairly sure that's a column driver so removing it will mean you get a big black bar down the panel.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by realdealthill View Posthow did you get the back panel off your tv?? I have a un55mu650 i cant get off.
Lift the tool upward until the bottom corner pops, then slide the tool **upwards** and across the top prying upwards as you progress. Do the same for the other side.
DO NOT slide the tool along the bottom edge or you will destroy one or more ribbons from the address boards to the display.
John
