How to remove this message after bios repair of 6th gen hp pc?
    After bios repair of 6th gen Hp desktop and all in one pc, "SYSTEM IS BOOTING IN MANUFACTURING PROGRAM MODE" message appears on screen in startup. I tried adding build id, serial number, product number, product name and feature byte in bios setup but it didn't work. Is there an easy way to solve this problem because I am not so good at using special software for bios editing. Any kind of help would be greatly appreciated. Thanks.
    Re: How to remove this message after bios repair of 6th gen hp pc?
    can you attach your config.txt file
      Can you please tell me how to find that file? I can attach the original and modified bios file but don't know about config.txt file you mentioned.
        you need to use (BCU) biosconfigutilty tool to set the system info.
        its widely available to download here. once you applied the MDM popup will go away.
          you need to use (BCU) biosconfigutilty tool to set the info.
          Thanks for your help. Is it easy to use because I am not good at using special tools for bios.
            yes.
            https://www.youtube.com/watch?v=r2ubpyeUOB4
            https://www.youtube.com/watch?v=9T57ktw8n3Y
              Thanks. I'll try it tomorrow and let you know.
                If you repair bios via dump you need upload original bad file i will extract your all data and replace new file.
                  Here is the original bad file of Hp 400 G2 all in one pc.
                    Send me file you repaired.
                      I tried several times to recover the corrupted bios of these 6th gen hp desktop and all in one pcs by creating a recovery usb drive on another pc but it didn't work. It worked very well for recovering 8th gen hp desktop pc bios. Is there any way to recover bios of these 6th gen pcs through recovery usb?
                        Repaired file.
                          Repaired file.
                          Try this.
                            Try this.
                            Thanks a lot. I'll check it tomorrow.
                              Try this.
                              Problem solved. Thank you so much.
