Bios password From Bios File
This topic is closed.
    how can a password can be retrived from a password protected bios file?
    any idea , please.
    Re: Bios password From Bios File
    any idea , please.
    Its hard to retrieved password bios,
    but probably to clear a bios password file is more easy ...
      how to do that?
        how to do that?
        I cannot explain for the detail, you need many trial for that...
        but if you sure the password is store in the bios chip,
        After you get lockedbios file, and you must get update file from vendor, i usually use uefi tool and hexeditor, to mix that files...
          in most cases you have on vendor support site bios with no password, then hex copy serial and model info in unprotected file and flash that file
          or flash file from other laptop with no password
          Im Back... sort of...
            right Donald,
            but not all vendor give full bios, just update bios part,...
            This is my experience password bios case in this month,when there is hard to find CLEANDUMP bios file out there...
            this notebook is :
            LG-GRAM 14Z950 PASSWORD POWER ON;3x wrong input, the system will be disabled and no hashcode...
            i have no schematic,but i am sure if the password is store in the bios chip MX25L12873F,
            Tools:
            -any SPI Programmer
            -UEFITool
            -HexDump
            -7Zip
            in short words....
            1. With any Spiprogrammer(i use the olddevice LPT-NANOBIOS+willem software),you'll get the file DUMP.BIN(16MB)
            2. Find the update file (14Z950FB_x64.RAR)from LG site, extract 14Z950FB_x64.RAR with 7Zip.
            Find the \\BIOS\14Z950FB_x64\.rsrc\1042\FILE\177 (7.641KB) (no extensions)...177 file is updatefile.
            3. Now you have 2 files : DUMP.BIN(16MB) and 177(7MB)
            4. Open that 2 files with uefitool(to verify) if the biosregionfile from 2 files is exactly...
            you will see if the dumpfile DUMP.BIN(16MB) is full bios with (including descriptor region,me region,padding,bios regions(8files)),but for the 177(7MB) only bios region with padding, and 7files.
            Now compare 2 files, and find the identical files module from biosregion.... i got 6 files identical (guid name and size)
            5. - With UEFItool Replace "6 files identicalbiosregion" DUMP(16MB) with extracted "6 files identicalbiosregion" from 177(7MB)
            - Or you can use Hexeditor to copy/insert biosregion with help detail from uefitool (to get exact offset and size biosregion file)
            6. Save this file as newfile.bin(16MB), now you can close uefitool-177(7MB).
            7. Remember if newfile.bin(16MB) is blank serial nr,etc....to insert new serial nr,you can use LG_DMItool (like HP using NBDMIfit),,
            8. if you dont have dmitool, For the Serial Number etc,(writedown from bottom case),And you can use uefitool again to search sn from DUMP.BIN(16mb) for replace again to newfile.bin(16MB) OR you can use HEXeditor....
            your file ready to flash to chip...
            ##Just Sharing, Hope this way can help someone to Clear the biosPassw
              is there any way to see the password in rom file by the hex editor
              and if it wich line
              i hope to find my request here
                what machine is it?
                  dell inspiron 15 3558 bios password
                  already programed it with two file bios same board id
                  the issues the machine boot up after 16 second so i need to know if there is a way to get the password from the original machine bios.
                  by the way it work normal with original dump with the password on it
                    some laptops can reset the password using test-points on the board.
                    try to find a service manual.
                      where to download the uefi tool?
                        Here.
                          Can you explain the method to us by video
                            hi, how i use wxhexeditor to find the serial number of pc ? and mac address and part number ?
                            thanks
                              where i can find more about bios editing
                              can u explain that for me
                                hello sir how can i search the serial number in bios file using hexeditor...thank you
                                  Good question
                                  i hope someone help us
                                    use ufi tool ne alpha 32, drag and drop ufi bin and go to the bios section click expand and search for vssstore , expand and u have all those things in there. example csn , sku and others.
                                      plz explain in video format
                                        hello my original bios but i can't find the password how can i see the password of the bios
