LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by markus1741 View Post
    try this ...
    thxs
      Someone can make patch for This Yoga 11e 5th 20 ln ??
        If the SIO isn`t an SMSC MEC chip the patch will not work.
          Yes this is a Nouvaton IO. But someone send question to allservice and he said no problem, he can make patch.
            Hello Autopatcher works here is the result you can try it.
              Originally posted by black0hackers View Post
              need clear bios pass Thinkpad P1 gen2 i7 9th
              hi.some one help
                hi.some one help
                Try this, maybe work. If you can entering bios menu without entering password, then follow instructions on post 1 from inside the bios setup security menu. Don't forget to clear every security & fingerprint
                  hi any one can patch this i have try with tool auto patcher but have a error
                  regards
                    regards
                    In a Lenovo T540p notebook there are two BIOS chips you need the one with 4MB.
                    Because your chip with 8MB cannot be patched.
                    https://www.allservice.ro/forum/images/T540p_bios.jpg
                      x1 lenovo 3Genaration
                      hello I tried to delete the password of this bios no good result the computer rings at startup can patch it please
                        files bin locked
                          Originally posted by sinidi48 View Post
                          files bin locked
                          Hi, you can try this.
                          Patched with Autopatcher!
                            Hello to all!
                            My thinkpad x1 carbon 5th gen 20HQ I is protected with a SVP please patch my BIOS dump!
                            thank in advance
                              Originally posted by hsali View Post
                              Hello to all!
                              thank in advance
                              Try this ... good luck!
                                Originally posted by Markus1741 View Post
                                You can try this.
                                I don't know if it works.
                                hello;
                                thanks it works and now I can create a supervisor password
                                  thank you so much. but it not work. no display on, sound beep coming.
                                    @black0hackers: Try this patch and report results, instructions included.
                                      [QUOTE=SMDFleal sir lenovo bios password how to removd in
                                      .[/QUOTE]
                                      3rd gen 4 gen 5 gen 6 gen 8 gen
                                        FYI:
                                        I destroyed the diode D12 while updating the chip of my T450, because I first connected the adapter wrong.
                                        If your laptop does not turn on anymore (screen stays black and fan turns on briefly) then check the diode
                                          Hello.
                                          Can anyone please help me?
                                          Lenovo W530 (Kendo-4 platform), the password is in the BIOS.
                                          an attempt to use a patch from a starttopic results in a patcher error.
                                          D:\L>autopatch.cmd 4.bin
                                          Using UEFIReplace to inject 2 DXE drivers...
                                          [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
                                          4.bin is corrupted or does not contain a valid dump.
                                          There was an error... Aborting.
                                          Moreover, if I patch the same 4MB dump from the T540 (Kendo-1 platform),
                                          D:\L>autopatch.cmd 5.bin
                                          [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
                                          Looking for volumes to patch...
                                          [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
                                          Not found... Skipping.
                                          Done.
                                          PATCH FILE: 5_PATCHED.bin
                                          Good luck.
                                          everything goes well. I am attaching the original dump.
