can anyone please check my bios image what is wrong?
HP15 LA-D711P
Problem - blank display only backlight.
I have tested another bios image - all was fine but bios image was for mobo version with amd gpu.
With any HP bios you should check your bios backup BID number ,or bios part number using a hex editors search function. Yours is BID081F5
Then,search the forum to see if any bios have already been posted. https://www.badcaps.net/forum/showthread.php?t=66687 Post #3 has the virgin bios extracted from the update.
With this bios the DMI info is in one big block and quite easy to copy,again using a hex editor.To search for the DMI i use a tool called FileAlyzer and searchthrough the hex for strings, but you can use insyde bios tools,UEFITool, a hex editors File-Compare function ,or the keyword HEBTEST or other methods.
When you find the DMI area just copy it from your backup to the virgin bios,that will preserve the serial,Feature-byte and win key etc .
Attached is the bios with your DMI
