It seems like this should be possible...just the outer screen and diffusion screen from say TCL...could I not use that to fix an LG? Just throwing some manufacturers out there...
can I swap a screen from different manufacturers?
Re: can I swap a screen from different manufacturers?
Very low odds to find two models that use the same panel for different brands. I salvaged two TCLs once with the same model number and it was two different designs. One with integrated tcon and the second with a separate tcon. The easiest check is to see if it has the same tcon, then the panels will be the same. You can search the tcon part number in Shopjimmy and it will list models it's compatible with.
