HP Probook 470 G5 DA0X8CMB6E0 BIOS X8C
    Re: hp 470 g5 -repair bios files needed
    Originally posted by peste View Post
    try..
    system is booting in manufacturing mode
    what now to do
    it seems is not original my bios files which is corrupted
      what now to do
      https://www.youtube.com/watch?v=9T57ktw8n3Y
        my friend better for me is to find solution on my bios file or to find org bios file
          Try this one, if it doesn`t work then flash the one by peste and enter the DMI manually.
            Thanks a lot SMDFlea , its working perfectly
              You`re welcome
                Re: HP Probook 470 G5 DA0X8CMB6E0 BIOS X8C
                hi can you clear bios password on this backup bin please for hp probook 470 g5
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    Thank You very mach it works
                      Hello all,
                      i bought dead Probook 470 G5 with burned mosfet.
                      Now the machine is powering on,but with black screen,Caps lock and Num lock is blinking 5 times.After that fan goes at full speed.
                      I tried files in this thread even some from 450 G5 thread,but no luck.
                      Can you pls. try to clean my backup dump?
                      Thank you!
                        Originally posted by peterzz2007 View Post
                        Hello all,
                        Thank you!
                        HP ProBook 470 G5
                          Thank you Hoaca,but still the same problem.
                          I need to double check everything,this seems like something else,not a bios problem.
                            hi,
                            HP ProBook 470 G5 2RR73EA
                            with nvidia gpu
                            problem with bios.
                            can someone fix this bios?
                              Originally posted by osman68i View Post
                              hi,
                              with nvidia gpu
                              problem with bios.
                              try this and report
                                Originally posted by mrwab View Post
                                try this and report
                                fan spin full no video
                                  what's your problem with original bios?
                                    hi,
                                    with nvidia gpu
                                    problem with bios.
                                    HP ProBook 470 G5 2RR73EA bios clear ME file.
                                      thanks Hoaca388.
                                      its working
                                        Hi guys, i have hp probook 470 g5 that si flashing capslock+numlock 5 times followed by the fan turning on and ramping to maximum speed. The screen is off the entire time. Please help, here's the original bios dump.
                                          ProBook 470 G5
