Acer Predator G9-791 Troubleshooting
    Re: Acer Predator G9-791 Troubleshooting
    Originally posted by jasko_jacker View Post
    P5NCN KB_pins=26 PD0=26 PD1=25 PD2=24 PD3=23 PD4=22 PD5=21 PD6=20 PD7=19 BUSY=17 STB=8 AFD=7 INIT=6 SLIN=5 KSI4=4 KSI5=3
    che if pin1 on keyboard is pin1 on vertianov.
    Thank you for you help!
    Did not work. I think I have a dead ITE, give me the same error.
      I forgot to mention that since I change ITE, the "CON6000", that is the battery connector have 16volts on pin 8,9 and 10 and this pins should be ground.
        I'm testing the pins of IO with multimeter (volts) pin 111 is connected to a resistor, this resistor have 3 volts coming from the IO pin, but nothing in other side and sometimes when I touch with multimeter the fan starts. Already change the resistor and is the same.
          It's late, tomorrow I will change this IO with another one I have and will post the results. Thank you.
            Thank you.
              tell me you need to restore these details
