Asus 1001PXD REV. 1.1 blinking led light
    Hi this unit was ok when I recieve it but after 3 days , the unit wont power on it will ust blink the power led light continuesly withot pressing its power. I hope someone can guide me where to check and how to identify its prblem
    Re: Asus 1001PXD REV. 1.1 blinking led light
    First thing
    Check rtc section
    Do hard reset
    Re flash good bios or verify rsmrst#
      Things like this typically mean the KBC software is running, and there is something the KBC doesn't like. As stingerchamp said, do basic checks first.
        Originally posted by stingerchamp View Post
        First thing
        Check rtc section
        Do hard reset
        What setting should I set for my dso for reading RTCRST#
        pin 2 3.3v
          3v and 5V is present bios pin 1 ov pin 8 hav 3.3v
            Check resistances on all the coils. I assume the schematic for this doesnt exist?
              i have schem
                Then publish it. I found the one for rev 2.0 but 1.1 seems to be on paysites only
                  Im having a low impedance on this coil I cant I identify where to find it in the schematic.
                    Very simple, identify the IC next to it. If this is feeding a big chip like the CPU it may very well be the normal resistance for that rail.
