hi everyone
as the title says i got this board with a possible short in cpu
when i connect the power supply the laptop draws 0.015 amps and when press the power button the light in the same button turns on and quickly turn off at the same time that power input ligth do the same
its a hp omen dc1003la with a i7 9750h and a 1660 ti
when push the button the laptop max amp draw is 0.120 amps and turn off
measurement near the cpu show me a full short ill attach the image
how can confirm that cpu is shorted
i tried injecting 1volt and 1 amp limited but nothing get hot even cpu still cold , should inject more current?
the only low measurement is near the cpu other parts on the board sems to be fine
thanks in advance
thanks in advance
