Panasonic 37” LCD LED
    Picked up a Panasonic TC-L37D2 off the curb. When turned on it powers up and the backlights flash then it goes into shutdown mode with 10 blinks. If I unplug the white connector on the power board that goes into the back of the panel (picture provided) backlights light up bright for a few seconds then get dimmer, but the set stays on.
    If I leave the white connector unplugged and also unplug the small connector going to t-con board (picture provided) the backlights come on and stay bright.
    In both scenarios I get a picture with what appears to be some of the colors missing. Scenario 1 gives dimmer picture and scenario 2 gives brighter picture but both have missing colors.
    Any thoughts would be helpful. I am not versed enough to repair a board but can change a board if I know what the problem is. I can use a multimeter with some limitations.
    With the larger white connector plugged into the top of the power board, it always goes into shutdown mode with 10 blinks.
    Re: Panasonic 37” LCD LED
    I googled and found your service manual. They usually contain troubleshooting steps for the blink code.
      I found a service manual and did some testing with a multi tester. I found the white connector CN01 that I unplugged to keep the backlight on is not receiving correct voltage. Pins 1 and 12 are getting 172V. The remaining pins 3, 4, 5, 8, 9 and 10 should get 79v but are showing only 1.4v. When plugged in it causes a shutdown. Does this mean the inverter that powers the LEDs is bad?
      The manual also says 10 blinks points to ZWEI2 sos on t con board.
        Pins 1 & 12 are the LED supply voltage, 172v is likely correct, the other pins are the led string return lines, I would check the return line voltage on each of the 6 strings (with the led's connected) as the tv is turned on (and before the protection cuts in) I suspect one of the lines will check different indicating an open led string.
          +1
          Check the return lines with ref to circuit ground.
            I checked all the pins on CN01 and CN02 when tv powered up and before shut down. Pins 1 & 13 on CN01 and pins 1 & 12 on CN02 were 174v. All others were 158v. I didn’t see one that gave a different reading. The manual says they should read 79v.
              Originally posted by Mmatt View Post
              I checked all the pins on CN01 and CN02 when tv powered up and before shut down. Pins 1 & 13 on CN01 and pins 1 & 12 on CN02 were 174v. All others were 158v. I didn't see one that gave a different reading. The manual says they should read 79v.
              Are you testing the return lines using circuit Ground (chassis) as ref ground for the meter's Black probe as suggested?
                If you are asking if I'm grounding the black probe to the television chassis, yes I am.
                  The tech manual says pin 5 on A03 sends 3.2v to tv sub on. I am getting only 2.7v on pin 5 to tv sub on. Could that cause the tv to shut down when LEDs try to come on?
                    After rechecking, the tv sub on at pin 5 is 2.3v
                      If your Relay_5VS is present at connector A03, Pin 3, then TV_Sub_On is OK
                        Dick Barton, thanks for the reply. I will check pin 3 when I get home from work and post back around 4:30-5:00
                          Sorry I didn’t post back earlier. Got sidetracked with car trouble. Pin 3 on A03 has 5.97v
                            Here's an update now. This morning I noticed I left the tv on with the 10 blinks going all night. Now I have standby power only. No relay clicking on the power board and turning it on as before. It goes straight to shut down and blinks 10 times. I get 5.9v on pin 3 and 2.3v pin 5 on connector A03 on main board. I have 5.9v on pin 11 of connector CN03 of power board that looks like it should turn on DTV 12v but I'm getting 0v to pin 4 on CN03.
                            Before all this the power board was clicking and backlights flashed on then went into shut down. Has the power board failed?
                              Maybe look over your solder joints with a sharp eye, give m a wiggle test, see if any are bad/cold, can google bad joint images if needed.
