Clear me x455lj 3.1
    Clear me x455lj 3.1
    Hello guys... client brought this Asus X455LJ laptop...
    client says that he is using it then it hung then reset the unit here is the
    symptoms.. no display no vga or hdmi output. it just lit the indicator led. long press of power button shuts down the psu. spins the cpu fan 10 seconds after power press. no memory module for this type.. its built in.
    what i did.
    strip it off to bare minimum
    visual inspection for burnt parts.. no avail.
    try to run the unit with just mobo and power adapter.. no avail.. same problem..
    thinking of memory problem or bios dump problem
    cmos battery button is not available because unit has built in laptop battery.
    try first to reflash the bios.
    any suggestion guys.. thanks in advance...
    Never stop LEARNING because life never stops TEACHING!
    Re: ASUS X455LJ laptop no display no VGA-HDMI out
    updates.. i already reprogram the bios with most of the bios bin available in badcap with no avail..
    can anyone please clean me my bios bin..thanks..
      Clear me x455lj 3.1
      can someone clear ME my bios bin.. really appreciate your help.. thanks in advance..
        Re: Clear me x455lj 3.1
        try and report
          thanks very much truly appreciate it.. ill try it..
            Re: ASUS X455LJ - BIOS Request
            what i found is this unit with board model ASUS X455LJ VER 3.1 is using bios program with different model i search its bin file and found out bios model is for ASUS X455LF. that is why all of the bios i downloaded here in badcap for X455LJ is not working.. anyone experienced this?
              Post a picture of the green/white stickers with the model number ,on or near the RAM slot
                all voltages in the power coils are present.. 3.3v, 5v, 12v, 19v, 1.8v,1.3v, 1v and .9v. long press the powerbutton turn off the unit.. when you turn on the unit.. the cpu normally heats up with cpu fan running..can any one help me with this.. thank in advance..
                  This is just the bios requests section.Post the pictures i asked for. If you need further help beyond a bios request please start a new thread in the main laptop forum. By the way,both your bios request threads have been merged into one.....
                    post it tomorrow sir thanks..
                      ok sir..
                        Try this file repaired with asus update and me cleared
                        Your bios model is x455LF
                          thanks Claudiomfa ill try it..
                            here is the model number in the cover of the laptop and the board
                            the programmed bios is for X455LF ..
                              with your clear me bios.. i only have the 3.3v 5v and 12v in the battery section.. no voltage for 1.8v 1v .9v for bga processor and memory 1.35v
                              the unit is turned on with green led power and orange led lit for battery.. and it will turn off
                                i think this is just a bios problem. bios ic has 3.3v. vcc. ic is good read,verify and write in programmer is ok no problem with the eeprom
                                  Try this..
                                  x455LJ repaired and me cleared
                                    thanks for the time Claudiomfa really appreciate it.. ill try it tomorrow
                                      using your clear me no success. maybe this is not a bios issue
                                        try..
