asus TP300L-DW07H
    asus TP300L-DW07H
    need bios file for this model.........orignal is attached
    Re: asus TP300L-DW07H
    what is wrong with it???
    your post says TP300LD but bios says TP300LA
    try and se if it works....
    Im Back... sort of...
      yes u r correct its LA......
        i flashed with ur file ....it turns on but with no display....one more thing i noticed that with orignal file it takes .45 amps on power supply but with ur file it only consume .24 amps,,,,,,,,,,i think we need a good working dump
          can you try this
            its a intel mobo without graphic chip
              and its a LA not LD......thanks for reply.......
                I have a TP300LA that turns on but doesn't turn on backlight in the LCD (even with a replacement). Is this the issue you had? Did you find a resolution?
                  if its ati vga reflow vga
                    Mine was the LA and intel only. I found a fuse beneath the LVDS connector, beige colored with an H on it that had blown. Bridged it and I have backlight again.
                    So, for searching purposes:
                    Asus Q302L TP300LA motherboard, no backlight -- fuse is located beneath the board, under the connector and is stamped with an H! I am so relieved this resolved my issue
                    Closeup of fuse attached. Again this is for no backlight, but external video is fine issues.
                      ASUS TP300L need schema
                        Default asus TP300L-q302L bios
                          i have an asus TP300LA, after boot up the display going to flicker and the laptop sleep itself...
                          anyone knows this problem? tnx in advance brothers.
                            did you find a schema for tp300l?
                              did anyone find schema or boarview ?
                              i have this laptop with charging issue, maybe someone can help my problem ?
                              thanks before
                                I have that https://cloud.werry.ovh/s/Gwt2tF8Q8LQYA7B
                                  Merci beaucoup mes amis
                                    thanks
                                      Your post says tp300ld but bios says tp300la
                                      Try and se if it works....
                                      thanks bro u r always amazing working 100%
                                        Originally posted by bricewerry@live.fr View Post
                                        Thanks...
