Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Is it possible to extract bios password from Bios dump instead of clearing the password? I have a EliteBook 840 G8 and would really need to know some way to extract the bios password and se it in clear text.
    Best Regards
    Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Best Regards
    No,its not possible at this time.
      Best Regards
      A plane trip to Mars will be faster comparing the time needed to reverse the HP algorithm using brute force... It's not that simple friend!!
        Sad to hear that. Becouse i have 40 pcs laptops with same password, and now must unlock all of them one by one!
          corvette-6050a3217501-mb-a01
          hp elitbooke 840 g8 bios dump pls
            hp elitebook 840 g8 bios password
            i tried rcunlocker with no luck
            both chips are 32mb
            i uploaded both
            the one labeled extern is the front chip
            the one labeled intern is the one from the back
            thnx in advance
              Re: hp elitebook 840 g8 bios password
              both chips are 32mb
              i uploaded both
              thnx in advance
              sorry forget the dumps
                Here you are:
                Become a Badcaps supporter
                Thanks to all supporters.​
                  https://www.badcaps.net/forum/showpo...&postcount=201
                    is this patch for the main or the ec???
                      Originally posted by Vesko356 View Post
                      Here you are:
                      thank youuuuuuuuuuuuuu
                      it work0s
                      p.s / i tried the patch didnt work
                        Remove password
                          Originally posted by Bsolution View Post
                          Remove password
                          read post # 9
                            Not understand
                              Not understand
                              Use a hex editor and you will.
                                AA 55 3F
                                to
                                AA 55 3C
                                NOT UNDERSTAND
                                  AA 55 3F
                                  to
                                  AA 55 3C
                                  NOT UNDERSTAND
                                  do you know how to use the program HxD ??? enter the bios in the program and search in "HEX-VALUE" .... 48 00 50 00 5F 00 4D 00 55 00 44 ..... and in that region you will find ... AA 55 3F .. where it replaces with AA 55 3C ... this is an example ... you have to replace everything that is written in the notepad..after you modified the bios you write it on the bios chip ....
                                    I dont find aa 55
                                      I dont find aa 55
                                      press F3 and move on with the same value, if you can't find it there ..
                                        i dont find anything.i upload files plz help
