A2115 820-01779-04 replace t 2 Break Activation Lock
    A2115 820-01779-04 replace t 2 Break Activation Lock 1 remove motherboard 2. Remove the hot iron part of the FAN 3. Remove the T2 shield LID 4. Heat insulation with high temperature tape around t 2. 5. T26 with a BGA strip lock. Remove T2 Clean Pad 7. Replant unlocked t 28. On the BGA mark position note not to shift 9. Set up the T210. Install Brush DFU brush T211. Restore the T2 installation system 12. PERFECT REPAIR INTO THE SYSTEM
    Re: A2115 820-01779-04 replace t 2 Break Activation Lock
    does it works for icloud removal? wich tool can i use to unlock t2?
      This process isn't as easy as you see it done in the images.
        i hace practice replacing CPU on iphones, i know about reballing process, but i need information for programming t2 chip on imac
          The steps is simple replace T2 chip with unlocked one then use Apple Configurator to restore it and voila.
          The problem is 1st.Hard work 2nd and most important there is no place to find T2 Chips Locked or Unlocked only from donor boards but who can say if have activation or no.
            is this hot air or different method ?
              Thank you for sharing.
