Lenovo Ideapad 320-15IKA NM-B452 not charging battery
    NM-B452
    Hi guys. I've used the forum a lot but never asked questions before. I had a Lenovo come in that was shorted on the 20V rail. I fixed that and thought my job was done until I realized it wasn't charging the battery. Here is what I've checked so far
    On the BQ24780SRUYR charging ic
    VCC 20V
    SMBUS lines
    SDA 3.3V
    SCL 3.3V
    Current Sensing lines
    ACP/ACN 2.3 ohms
    SRP/SRN 21.2 ohms
    REGEN line 6V
    PHASE .84V with no battery installed(this may be normal)
    PHASE xxV with battery installed voltage is slightly higher than battery voltage.
    Originally the battery was completely drained so I charged it with my DCPS. The machine will work on battery power. When the ac adapter is first plugged in the battery icon in the lower right shows that it is charging and it shows the battery filling up over and over for about 10-20 seconds. Then it stops but still shows that the battery plugged up. I do not get a message saying not charging. Feel free to let me know what I haven't checked. I have not tried a new battery yet because this battery seems okay.
    Re: Lenovo Ideapad 320-15IKA NM-B452 not charging battery
    Check to see if DCIN mosfets PQ311 and PQ312 is short or not
      ACDRV,ACOK,ACDET Voltage??
        No shorts on DCIN fets
        ACDRV 20.3V. BATDRV Same as battery V
        ACOK 3.27v BATSRC Same as battery V
        ACDET 2.9v TB_STAT .785v
        HIDRV Same as battery V BATPRES .298v
        LODRV 0v PROCHOT .3mV
        BTST 6.85v PMON 10mV
        ILIM .79V IDCHG .398v
        CMPIN .276v IADP 26V
        CMPOUT .520v CMSRC 20V
          ACDRV 20.3V.
            Hi piernov. I just reread through your sticky on charging circuits. When i think short I think short to ground. Sorry for the noob mistake. PQ311 is definitely bad
            PQ311
            0 ohm between Drain and source
            170 ohm between Drain and gate
            170 ohm between gate and source
            PQ312
            9Mohm between drain and source
            OL between drain and gate
            OL between source and gate.
            I’m not sure if PQ312 is okay or not. After I have replaced PQ311 what V should I see on ACDRV
              As per the TI datasheet, the gate voltage (ACDRV) should be ~6 volts higher than the source voltage.
              So you should see ~25 volts.
                I did read that but I just wanted to ask. I’m still new to some of this. Now to locate a replacement that won’t take a month to get here.
                  Now to locate a replacement that won't take a month to get here.
                  Aliexpress is not too bad but yes it *may* take longer than sourcing locally.
                  See attached. TI has stock of the part at this time of writing. While you are at it, consider to buy drop in replacement mosfets for the same repair. If TI has them in stock, the part will be great as spares for your parts drawer.
                  I think some datasheets, including this one, are written in a format that only twins can understand. Chargers are a hot (no pun, ok a small pun) topic here.
                  See my post and the excellent reply from the TI engineer here ( a must read ):
                  https://e2e.ti.com/support/power-man...114776#4114776
                    Definitely over my head. I think that reply he gave came from the data sheet too. I tried locating that part at www.ti.com but did not see it the first time. I’ll check again later
                      Glad you found the problem.
                        Thanks for helping. You were spot on.
                          Digikey for the win.
                            Hello team, I am having same charge battery issues with the same model.
                            The SRN_R line was blown internally at the pcb and the pcb was lifted a bit at that spot.
                            So far I have cut both lines SRN_R & SRP_R just to be sure and connected them by cable to PR317, replaced PR338, PR328 & PU301, checked PQ311 & PQ312.
                            ACDET 2,66V
                            ACOK 3,32V
                            ACDRV 24,11V
                            ILIM 0,84V
                            SDA & SCL 3,33V and connection to kbc & battery
                            HIDRV 7,44V with battery voltage 5,85V or 7,80V with 6,15V [second battery]
                            I have orange flashing led 3 times for as long I have a battery connected.
                            I can find nothing wrong with it, any help will be appreciated.
                              Remove all power and measure the resistance of the current loop but directly at the ic pins for SRN & SRP.
                                It is 20,16 Ohm
                                  Ok resistance.
                                  What is the voltage to ground of BATT_TEMP = pin # 15 (BATPRES#) on the charger IC?
                                    It is 3,33V without battery and 0,30V with the battery connected.
                                      What is the voltage to ground of REGN (pin #24 = BQ24780_VDD) ? This should be ~6 volts.
                                      Test with a known good battery. The conditions look ok to charge the battery.
                                      Perhaps the battery is locked.
                                        REGN is 6,02V
                                        The fact is that I have a similar model that has same charger [24780s] and can take either 2 cell or 3 cell batteries [currently has 3 cells] so I tried these 2 cell batteries there and they charge [stable orange led].
                                        After I took the working 3 cell battery and tried at the faulty motherboard one just to confirm that it cannot charge it but it does powers on with it.
                                        I'm wondering if bios could cause such issue.
