Sony Bravia KD43XF7596BAEP - Android no picture
    Re: Sony Bravia KD43XF7596BAEP - Android no picture
    maybe check the caps on on panel driver board/s.
      TV is now 3 years old.
      We bought it arround 05/2019
      It worked flawlessly, no problems and now this.
      I'll let you know if I fix it, thanks everyone for quick response.
        On the T-con board, check the voltage at the control points designated V15/ V25, etc.
          You need to check t-con voltages and data lines. But I would suggest getting a new t-con.
              Thanks, i'll do that tomorrow.
                this one worked fine, then I think I went to switch from tv to hdmi source, them bam no video or backlight, no warning and no acting strange like some will do before a problem gets worse, just straight from working fine to that problem described.
                  HDMI ARC is only for audio channel return right ?
                  So i can't connect this tv to another display to check if OS is working correctly.
                    HDMI ARC: https://www.tomsguide.com/us/hdmi-ar...ews-26262.html
                      Originally posted by nomoresonys View Post
                      Yes it's audio only.
                      It can't do video output to other display via HDMI to check if it works on other monitor.
                        Dont play any more with ribbons... you will damage them. take out the white heat sink of the MB Soc. and tell which type MT or MS.. also you have several Fuse on MB which are with F marked.. need to check them all with yours DMM, also remove the WIFI usb from MB and do hard reset again..
                          Motherboard works 100%.
                          I can hear all the sounds and even picture is decoding.
                          I am pretty sure it's T-Con.
                            I'm having almost the exact same issue with a Sony Android TV. Have replaced power board and mainboard so I think they can be ruled out. Left right panel ribbon behavior the exact same as you when they are removed.
                            I'm thinking it could be a dead TCON as well as a dead panel. Did you ever fix this?
                              Probably eemc chip is dead on both mainboards.
                                Disconnect lvds cable and make a jumper from mainboard 12v out and tcon 12v in, or mask every pin ov lvds cable except 12v, then turn on, screen should perform a self visual test..
                                  Nick's tv fixing dead eemc: https://www.youtube.com/watch?v=YL123l67h6w
                                    Update. Just did the tape trick, got video for about 10 minutes while I went through the android TV setup. Then all of a sudden green horizontal bands and the display goes black. Can still hear the android menu music but no picture again. So panel issue confirmed? Hopefully that wasn't the panel nuking my TCON board cause I tried to make it work...
                                      i can suspect your tape trick was not done well and/or you can have a partial shorted cap/diode on panel's distribution boards..
                                        Great guess. Just had a very small bit of tape on pin 1 and it must have moved. Used a bigger bit of tape over pins 1-4 and we have picture back again. What's the downside to covering up more than a single pin? Worse image quality?
                                          Worse image quality
                                          sometimes yes
