Fixing a multimeter based on VC9805 schematic
    Re: Fixing a multimeter based on VC9805 schematic
    Thank you for your reply. The m6 smd I marked in the photo and diagram was a short circuit. I don't have an m6 transistor right now. What should I do to operate the multimeter?
      Ok, that transistor matches the schematic for Tp2, controlling battery power to the multimeter, for the auto-power off.
      If it was shorted, the multimeter would stay powered on, it would not auto-shut off. The on/off switch would still work.
      It would be rare for that transistor to fail short-circuit. It seems strange. Unless there is another shorted part on the board, like a C2 or an IC.
      You can just short C-E with a jumper and the multimeter would power up and work, just no auto-shutoff feature.
        auto-off is a pain in the ass anyway.
          Yes, it doesn't turn off automatically. you guys are great. thank you. good people like you will save the world... so why can't I measure voltage and current? only ohm and diode (buzzer) are working. I couldn't find any other short circuit, contactor wires are in place. Could you please give an idea for this as well?
            Now the multimeter is working but it doesn't measure voltage and current. Do you have any idea about it?
              vc9805 multimetre arızası
              hello, I have the same vc9805 multimeter, whose photos and schematic I have attached below. After replacing the battery only ohm and diode (buzzer) measurements work, other measurements do not work voltage, current ... none. Only the number 1 remains on the screen. When I measured the components, I couldn't find any problem parts. If anyone has any idea, what should I do?
                Re: vc9805 multimetre arızası
                check all the transistors for shorts - some are used for input protection.
                  I checked all of them, unfortunately I can't find it, I don't understand where am I doing wrong?
                    did you move any of the contacts in the rotary switch?
                      Post #28 I said to use a multimeter and measure some voltages "On DCV 20V range, measure the A/D voltages: IN HI, IN LO, REF HI+, REF LO-, COM wrt V-"
                      That is 5 readings to take.
                        I will measure and reply immediately. Sorry, I missed your message.
                          sir,
                          buzzer = 2.90 v
                          temperature = 38.1 millivolts
                          in low- in hi= 0.00
                          vref+-vref- =1
                          v- v+ = battery voltage 9.0
                          v- and com varies 179 mv, 190, 110
                            Display shows 1___ with those readings?
                            Pin 40 COM voltage is too low, it needs to be at least 1V above V-. On the schematic it would be QC4,QC3 to check- that would short COM below 1V. On your board check whichever two are the same transistors as those. 9Q1 maybe?
                            There should be two protection transistors between COM and V-. If your meter does not have them, the IC can get damaged on pin 40.
                              sir, If the multimeter will measure the battery at 20 volts dc, which ways do the contactor wires touch in this diagram?
                                I solve the problem. I change the u2 integrated diagnostic tl062 in the diagram and the multimetrem started working as it old. If anyone experiences the same problem with me, remember this and benefit from this information. Thank you so much to the good people who answered my questions here...
                                  So does the transistor test and temperature ranges are working?
                                  Originally posted by poker View Post
                                  vref+-vref- =1
                                  So you mean both these two pins are 1V WRT GND or is the difference between the two 1V? If it's the former, we need to look at how these voltages are being generated. If it's the latter, throw away the meter and buy another one...
                                  Ah okay looks like you fixed it, excellent. If it's easier just to replace parts until it works, it's still much faster than doing systemic debug... hence replacing whole meters is sometimes easier.
                                    I couldn't find a fault anywhere, then I wanted to replace this part and yes it works as before now, temperature, voltage, all... thank you very much for your help...
