Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Thread Tools Display Modes
Old 11-07-2019, 02:00 AM   #1
caspian
City & State: Mainboard
My Country: Laptop
I'm a: Hobbyist Tech
Default New Tiny Pad Installation
Dear Forum Members,
Yesterday, I removed a corroded IC from a laptop mainboard (as in the photo). During this process, Pad 19 got ripped off. This pad must be connected to the capacitor above it.
Unfortunately after cleaning, the ground copper appeared under Pad 19. I have to install a new pad on Pad 19. The new pad must not touch the the ground copper.
What is the cheapest substance or glue that I can use to cover the ground copper and install a new pad for Pad 19?
I do not have solder mask. Can I use any other substance for this work?
the substance must be heat-resistant as I will apply heat to solder a new IC on these pads.
What are your recommendations on this work?
caspian is offline   Reply With Quote
Old 11-07-2019, 08:45 AM   #2
KvnTM
City & State: Arnstein, Bayern (Bavaria)
My Country: Germany
Line Voltage: 230VAC 50Hz
Default Re: New Tiny Pad Installation
I'd recommend some sort of uv glue, epoxy or soldermask.
KvnTM is offline   Reply With Quote
Old 11-07-2019, 10:02 AM   #3
caspian
My Country: Laptop
I was thinking of using Silicon Glue that can tolerate 200'C. It will cover the ground copper and will hold the new pad too. But I do know if it will be suitable for this job in practice.
Old 11-07-2019, 11:33 AM   #4
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
I'm a: Knowledge Seeker
__________________
budm is online now   Reply With Quote
Old 11-07-2019, 12:09 PM   #5
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Why don't you just install the new ic, then run a thin wire from pin19 to the cap. There is no need to replace that pad, trying to will likely just result in a mess or more damage.
R_J is online now   Reply With Quote
Old 11-07-2019, 01:13 PM   #6
caspian
My Country: Laptop
Thank you.
I forgot to mention that the IC is QFN. So soldering a wire to it is difficult.
I thought there might be a standard way to repair such a damaged tiny pad. Is there such a way or I have to soldering a wire to the IC?
Old 11-08-2019, 10:48 PM   #7
megaraider
City & State: Porto
My Country: Portugal
Quote:
Agree
Before placing the IC:
- Make sure ALL pads retain connection
- Lift / bend pin 19 before soldering the IC
megaraider is offline   Reply With Quote
Old 11-09-2019, 06:04 AM   #8
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
Quote:
Originally Posted by megaraider View Post
Agree
QFN has no pins - it has pads like a socket775 cpu
stj is offline   Reply With Quote
Old 11-09-2019, 12:02 PM   #9
R_J
City & State: ☻
My Country: Canada
Maybe you could find a similar trace from a scrap board, Then fill the hole on the board with a bit of epoxy, then position the new trace on top of the epoxy. that should prevent it from touching the ground trace below pin 19 and also hold the replacement trace in place.
Old 11-09-2019, 07:31 PM   #10
megaraider
City & State: Porto
Quote:
Sure, that's why i mentioned "bend".
Most low count I/O QFN ICs usually allow the pads to be bent outwards the package (from backwards to the side).
Old 11-09-2019, 07:57 PM   #11
stj
stj's Avatar
no they dont, that's a PLCC package!
Old 11-09-2019, 09:07 PM   #12
R_J
City & State: ☻
My Country: Canada
You may be able to tack a small wire to the side of the ic on the qfn
Old 11-10-2019, 02:40 AM   #13
diif
City & State: Midlands
My Country: England
I'd use some Chemtronics thermal epoxy, it will take 315 șC for a minute. https://www.chemtronics.com/circuitw...hesive-syringe
Tin a fine piece of wire, lay it in place of the track, place QFN on top.
diif is offline   Reply With Quote
Old 11-11-2019, 03:35 AM   #14
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
The last time I had to deal with something similar to this on a Macbook, the customer had already attempted the repair their-self and subsequent damage to the board exposed one of the internal ground layers. I back filled the exposed area with a hard curing UV solder-mask, the remaining arrangements were taken care of with several preformed copper wires soldered to their related nearby components or tracks tinned and positioned under the qfn pads. Thermal re-flowing completed the repairs to a satisfactory working standard. Suggest plenty of practise before attempting this.
llonen is offline   Reply With Quote
Old 11-11-2019, 03:11 PM   #15
megaraider
City & State: Porto
imo some QFN allow it to be done... or at least trimmed from backwards to the side (see picture attached to this post)
Old 11-12-2019, 02:25 AM   #16
caspian
My Country: Laptop
UV light is usually applied to a mainboard when there is no IC on it. But I have to apply it when there are various kinds of ICs on the mainboard such as CPU, North-Bridge, Embedded-Controller, Buck-Converters, Mosfets. but there is no UV-sensitive EPROM on it.
The mainboard belongs to IBM Thinkpad T61 laptop.
Can UV light damage any IC on this mainboard?
Old 11-13-2019, 04:12 PM   #17
megaraider
City & State: Porto
No it won't. But protect your eyes!
Old 11-14-2019, 08:06 AM   #18
RethoricalCheese
City & State: Tartu
My Country: Estonia
I am working on iphone boards and most often there is a broken trace which needs to be repaired. 0.01-0.02mm wire, UV glue and UV lamp are very good for that job.
For your case 0.1mm wire should work fine. Just cover the ground with a very small amount of UV glue and let it dry under UV lamp. Then clean that wire, solder it to the capacitor and place it where it needs to be. Cut to lenght and apply a new layer of UV glue on it, let it dry under UV again.
Btw, that is far from tiny
RethoricalCheese is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
