The CCFLs are not lighting up at any moment, when the fault occoured the lamps shut down and only sound still played, there's image on the screen, with a flashlight I tried turning energy saving off, no change, PWM_DIM signal is 0.2V, I isolated the pin and soldered a 3.3V regulator at it but it still does not work.
All the main voltages 24V/5V/12V are ok, the mainboard is not sending enough PWM_DIM signal voltage.
1~5 - 24V - 25.01V
6~10 - GND
11 - BRI - 1.54V
12 - INV_ON/OFF - 5V
13 - PWM_DIM - 3.3V (with an AZ1084 3.3V regulator)
14 - ERROR - 0.04V
The only signal left to manipulate would be BRI, but I do not know what voltage it's supposed to be.
Disconnecting the ERROR pin does nothing.
That floating IC next to the inverter cable is the 3.3V reg, currently disabled(no Vin).
1~5 - 24V - 25.01V
6~10 - GND
11 - BRI - 1.54V
14 - ERROR - 0.04V
