Samsung UN65NU7300F bad T-Con?
    I replaced the right side LED strip on this Samsung UN65NU7300F. It went well but I had to disassemble the TV again to adjust and really glue down the strip. Long story short, I ended up snagging one of the display buffer boards while walking past the LCD panel(I didn't use enough masking tape and it got loose).
    Now about 6 traces on the display buffer board are not connecting to the ribbon. I can't seem to get the ribbon traces to connect to the board traces when pressed together this doesn't affect the screen. Could trying to fix this issue have damaged the T-Con board?
    The left side has excessive brightness and reducing the backlight setting has no effect on it.
    The TV has 216 T-con PMIC fault counts, does it need to be changed at this point?
    Any help or advice would be welcome, thanks
    Re: Samsung UN65NU7300F bad T-Con?
    You need to try to fix those traces or I'd part out tv. how about a close up of the busted traces.
      No busted traces, just the part of the ribbon that's circled in the photo has detached from the buffer board.
        tab bonding - tv is parts
          there are some techniques to maybe repair it. Heat can sometimes be your best friend or your worst enemy.
