Good day guys
I got this very nice TV from a friend. It has this vertical band on the right side when in front of it. I've read a lot of your threads, and it seems as if vertical bands are almost always panel failure or problems with the panel.
If I remove the Tabs going from the T-CON to the panel, the left side comes up white as it should, although if the right side is disconnected, the screen right side is faint white, and with some vertical lines too. Voltage at the T-CON fuse is 12,2V.
I cleaned the tabs thoroughly, but see no difference. Can you please confirm if you think it's the panel, or hopefully is there anything else I can try.
Thank you for reading this, and any forthcoming help.
