Samsung ue32t5300ak
    Samsung ue32t5300ak
    SAMSUNG UE32T5300AK
    problem is standby light on just flickers when power button pressed same with remote, beleive its the dredded corrupt firmware if anyone like Lotas can check to see if its corrupt all voltages seem to be there
    still doing the same with screen, wifi, speakers disconnected
    regards
    gary
    Re: Samsung ue32t5300ak
    Here is a working dump, check with it.
      thanks Lotas, been trying but
      keeps coming up "chip %s with the contents are in disagreement"
      im using a bog standard progrm for the ch341a
        This firmware is working, checked more than once, maybe you have a problem in another. Checked to run without a panel? Here is another worker, try it.
          Hi Lotas I will try that when I'm home
          The error I'm getting is on the programming software nothing on tv screen was disconnected and still there was no change
          I will try your other firmware asap I'm out at the minute thanks bud
          Regards
          Gary
            So maybe you have a problem with eMMC firmware.
              Lotas you're a star god bless you
              It worked Tv it now working
              Kind regards
              Gary
                Ok!
                  Hi, I also just wanted to thank you lotas, as I stumbled upon this thread trying to fix my UE32T5300 with no picture/sound/backlight and only an intermittent pulsing power LED.
                  The second firmware on this thread (ENQ2540.zip) didn't work for me but the first one did (UE32T5300AU dump 25q40.rar)!!
                  Many thanks again for your great work!!
                    Thank you Lotas.
                    I have a SAMSUNG UE32T5372AU TV with the same problem.
                    Your Dump helped me. Thank you again
                      Hi after some advice I have the same tv with same issue I presume I need to purchase the ch341a then use this ti flash the firmware on my tv? any pointers would be a massive help Thanks
                          This guide may help https://www.youtube.com/watch?v=z9uLPo9QAY8
