LG 32LN540B power on problem
    The power board is EAX64905001 (2.7), over
    internet i found wiring for (2.4).
    May be the whole problem is that
    i have 3.13V instead 3.5V. When i power up tv
    the red led light up for ~10secs, then power off
    for 3-4sec, and again power on, power of, etc.
    In version 2.4 output 3.5V came from main transformer - D203-
    C201- LB201- C209-C210.
    But in my case (2.7) 3.5V came from IC202 (NR891D).
    In hid datasheet there is only info that from output must
    have 5kohm resistor to FB to produce 3.3V but i can`t find
    what control and how to calculate output voltage.
    I change both capacitor near to LB201, but this did not change
    output voltage of 3.5V line - it stay 3.13V.
    What other to check?
    Re: LG 32LN540B power on problem
    Pictures?: https://www.badcaps.net/forum/showthread.php?t=39740
      Originally posted by nomoresonys View Post
      Thanks. I upload pdf that i have for 2.4
        If you haven't already, unhook cable from powerboard to mainboard and test the pins on powerboard, see what voltages you get and if they are steady.
          It is better - 3.45V
          So, may be fault mainboard?
            seems to be dragging it down a little, try testing the powerboard as stand alone, with tv unplugged from power, unhook cable from powerboard to mainboard on mainboard side, I jump it thru the end of connector by tracing the wires from the powerbord side to the cable end, take three 1k ohm resistors and jump from PWR-ON TO 3.5, DRV-ON TO 3.5 and P-DIM to 3.5, plug power cord in, see if backlights come on and stay on and the other voltages come up to expected levels.
              There is backligh, voltage is 66V and other voltages seems to be OK
                Seems like a mainboard issue then.
                  May be yes. Thanks for all your support
