Sony kdl 40ex720 firmware update
    Re: Sony kdl 40ex720 firmware update
    You have that the backlight is not working, you can insert the cable back when error 5 appears.
      You mean if I plug back the lvds cable when error 5 appears I am gonna have backlight?
        Originally posted by lotas View Post
        Try disconnecting the LVDS cable from T_CON and turning on the TV, when the backlight turns on without turning off the TV, insert the cable carefully back quickly and without distortions, an image should appear, reset and update via usb. Do you have firmware PKG4.027EUA?
        yes i have that firmware
          To Lotas, if the tv shows an error code i think is in standby protected mode, it can't turn back to On mode.. To Dino: alternating green-yellow is typical of Sony when detected an hardware pairing change between mb<>tcon, you need to find the key conbination to force update, since tv is already updated it normally refuses updating... have you read the service manual?
            Yes I saw the service manual and I read that you can't update if it has the latest firmware but I I didn't find anything about force update.. Do you know the key combination for the force update?
              no i was meaning the reset procedure
                And how can do that please?
                  i don't have the manual on the tablet, don't have wish to watch non the pc.. for now
                    Ok i will check the manual thank you
                      When it enters recovery mode, it doesn't matter to it what firmware you installed on usb, as long as it is not lower than the one that is currently installed. How do you prepare usb flash for upgrade?
                        I format it to fat32 and I unzip the folder to the root of the flash drive as the manual says.
                          Try it - the firmware file itself is "00000100_07e8046a.bin" (without folders). And without quotes.
                            I try it but no luck
                              There is another option, do you have a good command of a soldering iron for smd components?
                                Yes I can solder smd components
                                  I understand from your topic that you replaced the T-con board, I hope the old T-Con board remained (what happened with the old board and which one you changed to (diagonal, model ..). Write in detail your actions.
                                    No sorry maybe I didn't explain well.. I replace the batv board not the tcon board
                                      Then this option, which I wanted to offer, will not help (I thought it was T-con), then only an update via usb.
                                      And can you buy a native T-con, where did you get the motherboard? Or he had a different diagonal.
                                        What do you mean a native tcon? I bought a used batv board from 46ex720 tv not for the 40 inches one that I have.
                                          he means the tcon originally mounted in the same tv where the spare mb came from..
