Technika 32E21B Usb Firmware
    Hi guys,
    Wondering if anyone would have the usb firmware for this tv?
    Re: Technika 32E21B Usb Firmware
    If this is a simple TV (not Smart), then it is unlikely that the manufacturer released an update for it via usb, but what is wrong with the TV?
      Hi
      These are renowned for corrupting firmware, sometimes starts, but normally sticks in standby- 100% positive this is the fault.
      Did try similar firmware found for blauplunkt(same main brd) now starts ea time but screen different /corrupt.
      I know if I get the correct one it will take it and work.
      Its just finding someone who has it I suppose.
        Do you have a TP.MSD306.P72 motherboard? And the panel (matrix) you have is LC320EUN?
        If you updated with firmware via usb from blaupunkt, what was the name of the update file? "Merge" ?
          Hi
          Its the TP.MSD309.BP85 motherboard, that does sound like the screen but I will have to look it up to be sure.
          It was firmware for this M/B but blau I loaded- just was different screen(was all I could find in days of searching- thought if lucky screen might just be inverted and reset in engineer screen but not that lucky.
            Yes, now, in order to select the firmware, you need to know the exact motherboard number and panel number (since the panels have HD and FULL HD resolution).
              Hi
              just rechecked there- thats the correct board model & the screen is LC320EUN-SFM1
                I searched days for this using the TP.MSD309.BP85 board & LC320EUN screen numbers couldn't find this usb software anywhere.
                Anyone who may have this software would be a very welcome help with this?.
                Thank you.
                  Hi
                  Do you know where it is possible to select this firmware from?
                    If I even could get the usb file for a different make tv that has the same M/B & screen I would not mind if only the splash screen/manufactures start up name was different?
                      from what i know.. this MB most the time get defect at DC to DC Req. which support RAM / CPU low voltage 1-2 -1.3V.. i would first follow the low V circuit.
                        Hi
                        Thanks for your reply, I am 100% certain its the firmware, its listed as a common fault, plus the firmware I found worked/cured the startup/standby problem - just wrong screen type.
                          I found the firmware from Q.Bell QXT.32KF TP.MSD309.BP85 (LC320EXJ-SE E1) for the programmer, but the last letters in the panel number are slightly different.
                            Hi
                            Thank you, I do not have the programmer, does it have it for usb?
                              It will be possible to try via usb, here it will be necessary to correctly rename the file so that the update via usb goes, post your update file that you installed on the TV (from Blaupunkt).
                                This was the one but wrong screen.
                                  Ok, try.
                                    Ok, try.
                                    Lotas Thank you.
                                    I had one of those files before, tried again both, but didn't work.
                                    Still same screen corruption- flashes on initially then goes black.
                                    (I just remember the remote sequence/buttons to access usb upgrade).
                                    Looks like it maybe for the skip.
                                      But at the moment, the native remote control may not work or not correspond to the buttons, since you changed the firmware for blaupunkt and the code encoding could change in the firmware.
                                        Hi
                                        yes I had thought of that but as I press the part for upgrade from usb it reads the usb/the usb led flashes.
                                        If not that I feel its lost as cannot see the screen.
