The Hall of Shame - Badcaps Photo Montage
This is a sticky topic.
    Re: The Hall of Shame - Badcaps Photo Montage
    I have a question. I've replaced about 1000 caps in the last year and I have a huge bin filled with the bad caps. I've seen plenty of Panasonic caps on boards, but I've never had to replace one. Most of these are the miniature ovens that will kill most any cap with time. I've replaced hundreds of Rubycon caps in GX270 and SX270 models, but the Panasonic caps are always fine. Does anyone ever come across bad Panasonic caps?
      Yes, all the time in GX620's, SX280's, SX270's, GX745's, and many others.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        Originally posted by kgordon View Post
        Here are 4 photos of the bad caps on the EVGA e-GeForce 7600GS video card. I hope they are clear enough. If they aren't, I'll redo them.
        As I said, when this thing blew up, it took out the mobo too. :-(
        Those look very similar to the ones on this FX5200 I found lying around in my parts bin. 3 X F72 1000uf 16v's & 2 X F272 1000uf 6.3v's
        Will any cap with a good rep and the same ratings be sufficient?
        I'm considering popping my cap cherry on this card!
        Can you guys recommend the right parts to replace them with, and if there's any fellow Aussies here, if there's a reliable local supplier of decent parts?
          These for the bigger ones, these for the smaller ones. Yes, it is OK to replace a 6.3v cap with a 10v cap. Unfortunately, No australian suppliers sell them, so you have to order from overseas.
            Thank you for replying with those links
            Are they the same as these ones from Jaycar?:
              Orpheous, where are you ? - good idea to use User CP (User Control Panel) on left near top to include location in your profile
              Is it Jaycar NZ ?
              In Melbourne, Jaycar discontinued Samxon in favour of Suntan - Suntan has the bullseye type of bung that usually identifies bad caps
              The Samxon that Jaycar used to stock in Melbourne were type GF, whereas recommended types for motherboards are GD, GC & GA
              Samxon type GF have a poor reputation on this forum, with bad ones showing up often in threads about displays
              Having said that, I used GFs from Jaycar a while ago to fix some Epox SocketA motherboards, with a successful outcome
                No. They're not the same. As I said, I don't know of any australian suppliers that carry suitable motherboard caps. If your lucky, you may get away with using them, but it is NOT recommended.
                  Thanks fo the reply, I'm in Cairns, FNQ... CP changed to suit
                  Is it Jaycar NZ ?
                  I was just looking at the Australian site, which doesn't specify the series, only a part number. I still have much to learn!
                  I'm still considering giving them a shot, the card is one of about 30 that have been put aside for testing, and it's only worth about AU$40 new (circa '06 AGP w/DDR) so if it works it's a little bonus.
                    Orpheous,
                    Pictures of low ESR capacitors on www.jaycar.com.au are probably out of date and their shops only stock Suntan
                    Is there a Jaycar shop or agent in Cairns, or do you need to mail order ?
                    If there's somewhere local that stocks Samxon GF, probably worth giving them a go, seeing FX5200s aren't worth much
                    Even Jaycar's Suntan, provided you don't have high expectations of long life or intend to put repaired FX5200s in critical systems
                    If your first try is a success, you'd need to think about getting future capacitor supplies from overseas
                    Problem with overseas is cost of shipping, and possibility of getting fakes if you buy through eBay
                    If this was my first try, I'd pay Jaycar's exorbitant price for capacitors to do one repair, and see how it went
                    Jaycar's low ESR capacitors used to be all 10v - as c_hegge advised, it's OK to use 10v as replacements for 6.3v, provided dimensions are suitable
                      Just thought I'd reply to say thank you to those who have posted useful information here in the past, and especially to pfrcom and c_hegge for steering me in the right direction with local supplies.
                      I ended up going down to the local Jaycar store, rifling through their low esr stock and buying a heap of their old Samxon GF stock which I used to successfully repair 2 old FX5200's and an MX440.
                      I sourced some decent caps (Nichicon HZ's) and when they arrived the other day I had a go at replacing some bulging caps in the power circuit of an HP 17" LCD panel that kept turning itself off.
                      So far only 1 of the graphics cards that I've tried to fix hasn't worked, and I'm enjoying bringing life to my old parts that I couldn't bear to throw away.
                        counterfeit nichicon vz.
                        like why bother?
                          samxon GF arent that great quality. they are unreliable. the GF=GirlFriends, and girlfirends are unreliable
                          @kc8adu: how can you tell those are fakes?
                            like why bother?
                            Makes as much sense as counterfeiting pennies.
                            Mann-Made Global Warming.
                            - Dr Seuss
                              color,print quality,bung.
                                That's ok, I'll be sure to not put them onto anything I have to live with, just a few dirty little cards on the side maybe ;P
                                  Stone caps from a TV Tuner card:
                                  The only PCI-E slot that the card was able to be used in positioned the 85C caps only a few millemetres above the southbridge heatsink.
                                  Ripple rating on the "general purpose" Stone caps was 740... I didn't have any 105C general purpose suitable caps around so I used some Chemicon KZE 16V 1000uF caps instead. Although the KZE's have around 3 times the ripple rating, the card has been running flawlessly since I swapped them out
                                    Well that's the point - higher ripple ratings = better.
                                    A working TV? How boring!
                                      another fake capacitor
                                      more info
                                        printing is wrong too.should be readable with the leads down.i dont remember any mfr doing the opposite.
                                          I don't know of any Australian suppliers that carry suitable motherboard caps. If your lucky, you may get away with using them, but it is NOT recommended.
                                          Wiltronics in Alfredton Victoria are (amongst other things) a Jaycar sub-agent, they stock lowESR Hitano capacitors (EXR series) which I've used to successfully repair motherboards & power supplies and compare well in specifications to the premium SamXon offerings (which I use when I have stock)
                                          Viva LA Retro!
