dell xps 13 9300 fdq30 la-h811p rev:1.0 bios
    need this bios the laptop get dell logo then restart and this is the dumb file
    Re: dell xps 13 9300 fdq30 la-h811p rev:1.0 bios
    clean file try reply me post
      same problem
        same problem
        this file try and reply me and hdd and ssd m.2 remove it,
          Can anyone help me clean up the dell xps 9300 dump?
            Re: Can anyone help me clean up the dell xps 9300 dump?
            try or reply me post
              I have the same problem.
                The same problem. Logo and nothing else. I try to reprogramming BIOS chip few times with diferent dumps. Nothing. But. I found, that one of the C-USB didn't work, even power supply, so i found bricked chip TPS6987D, it was very hot, I replaced it, but the issue persist. Maybe PCH is bye bye. Any idea?
                  Originally posted by pitmakot View Post
                  i have the same problem.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    yeap exactly the same issue, replaced it twice and it boots show the logo and reboots, cant access the bios or boot options and the port still don't work after replacing the chip.
                      I can't find the schematics or boardview for this model, can anyone point me in the direction which chip is the bios chip on here because I see 4 winbond chips in total
                        Ok managed to find the bios chip, and removed it, this is the dump, can anyone check it and clean it if needs it?
                          Can you post the other 3 winbond dumps as well.
                            theres 4 winbond marked red and 1 PCH SPI Flash ROM 32M marked yellow. Do I have to desolder all 4, read them and save and upload dumps?
                            Here's a copy of the boardview and schematic if anyone needs them https://www.badcaps.net/forum/showthread.php?t=106344
                              Try this bios.
                                Originally posted by SMDFlea View Post
                                Try this bios.
                                Cheers for sharing, I've reflashed the BIOS but the same issue persists. Shows the Dell Logo and reboots. Testing the USB C port with an AMP meter shows a dead port ie no power. The other USB C port is fine. Still can't access the BIOS by pressing F2 or the boot options via F12. No shorts present on the board.
                                  Try
                                    Originally posted by hoaca388 View Post
                                    Try
                                    Same issue. Also, I tried copying the bios from the Winbond chip from the known good (right) side USB C port over to the port where the TPS65987D chip has been replaced, and again exactly the same issue... Just boot looping.
                                    Running the LCD diagnostic test works fine, but still cannot access the bios or boot options.
                                      Can anyone clean up the la-h811p dump?
                                        Originally posted by quic307 View Post
                                        can anyone clean up the la-h811p dump?
                                        xps 13 9300
