Hi, I am a newbie on this forum, and in logic board repair. I am wondering if anyone has ASD for 2010 and newer, such as ASD 3S150, 3S156 and up? Hope i am not violating any rules requesting this...
I am looking for Apple Service Diagnostics
Re: I am looking for Apple Service Diagnostics
https://drive.google.com/file/d/0ByC...oyTDFnX1E/view
Originally posted by adiljan View Posthi there i am looking hardware test file for macbook pro 15 inch mid 2014 .i think file name is asd 3s162 plz help me thanksAttached Files
Anyone have the ADS for Macbook Air 2014?
I am telling you the story of this 2014 Macbook Air 13.
It comes without liquid or sulphate damage. But with the fan at maximum speed.
I perform the Test, generate the PFM006 and PPN00 errors.
I need your help. Anyone have the ASD for the 2014 Macbook Air? . ASD 3s162 is not for this model. see the image
Originally posted by mon2 View Post@MOMOS_GSM, unless I am mistaken, do not believe there are ASD as stand alone tools for the current models. They stopped this years ago from a post on one of the forums. The tool is cloud based and needs authentication to access it.
is there any other software that can test the sensors on macbook??
i have a macbook that is overheating
Try the following:
1) Power up but hold down the 'D' key and the Apple built in diags will kick in and report a simple status if a sensor has failed or not.
2) You can try TGPRO - free to test but ~$12 USD to buy it.
https://www.tunabellysoftware.com/tgpro/
Does your macbook work and you can see the display ?
Maybe you just need to remove the heatsink, scrape off the old (dry?) heatsink compound and apply a fresh batch ?
Also, be sure that the heatsink is indeed physically camped onto the top surface of the CPU / PCH or whatever to remove the heat.
