iiyama 24" E2407HDSV [DEAD]
    Hi lads, I've been trying for several months (mostly waiting for parts) to repair my monitor. Before its definitive death, monitor was shutting off and on repetitively and then it just died. Led is not lit, completely dead. Now i have replaced all caps, fuse, and mosfet. I tried to replace IC LD7576PS which didnt help me. ( https://cdn.badcaps-static.com/pdfs/...ce119f6336.pdf ) here are schematics, different monitor, same psu.
    What else could it be? What component is "triggering" something so it could start up.
    Re: iiyama 24" E2407HDSV [DEAD]
    https://imgur.com/a/yU9um5v
    this is the board
    IC LD7576PS has in datasheet:
    On/Off Control
    By pulling COMP pin lower than 1.2V will disable the gate
    output pin of LD7576X series immediately. The off mode
    can be released when the pull-low signal is removed.
    what does this mean?
    then this : Over Load Protection (OLP) - Latch mode
    "... As soon as the
    over load condition is removed, the controller will be kept
    latched until the Vcc drops lower than 8V. It is necessary
    to start another AC power-on recycling to get the output
    back. "
      Could Faulty OZ9937GN lead to monitor not turning ON? Even if its IC for CFL. what component of the monitor is Turning monitor ON if PSU has every voltage right - potentionaly.
        Just to be clear:
        1) Do you have ANY DC Voltages on that white connector of the power supply board that goes to the main/logic board?
        2) Power supply board is an always on power supply, it is always running, the main logic board will send out the BL-ON control signal to turn on the backlights circuits.
        3) It that the pictures of YOUR board and not from the WEB? The caps looks original and I do not see any soldering works on the board.
          I have 0.035V going in white connector, and yes those pictures are from web unfortunately, But I tried my best to shoot mine. https://imgur.com/a/EJcrJuV
