ah, the first thread...
this thread should be for problems found in specific notebooks.
Please post make/model and what problems you commonly see, or mods that are too obvious.
also, you could post common notebook problems seen in most notebooks and how to fix them.
let me start...
compaq armada 150: no bios
this happens because the bios is on a secondary partition. discussed here
since the links in their article do not work, i found the files on driverguide and put them in 2 .zip files, attached to post. instructions:
if using an os with no .zip support, install 7zip
extract the 2 .zip's
(rest of instructions from wireball.com)
Insert a floppy disk and run the Computer Setup for Portables SP8975.exe program - it will create one of the two floppies you need. Insert another blank floppy (or floppy you don't mind erasing) and run the Personal Computer Diagnostics SP12906.exe self-extractor to unpack files to a PDIAG folder. Inside the PDIAG folder, run MAKEDISK.BAT to create your floppy. Follow the onscreen prompts. Once you've created this floppy, you may reboot.
Insert the diagnostic floppy in the drive to boot off it as soon as you see the red Compaq logo (if Windows starts loading, you may hit F8 to bring up the boot menu, then ctrl-alt-delete to try again). (Re)create the diagnostic partition, by clicking the appropriate buttons and following the directions. This procedure seems to be non-destructive to data; at least it didn't destroy anything on my Windows 2000 system with a 376MB FAT swap partition and a 5GB+ NTFS partition. However, your mileage may vary (YMMV), so backup any data you want to save (bookmarks, documents, pictures, what have you), and don't blame me if you need to reinstall your OS.
Press F10 when you see the blinking cursor to access the BIOS.
other problem is there is no app for the hotkeys
solution: use the armada 4100 driver. download
*note* the hotkeys driver corrupts the acpi scripts in win 2k (maybe xp as well) and makes hibernate and sleep not work properly. keys detected in autohotkey, but i do not know how to program that.
if you have/know notebook issues like those, post 'em! somebody might need it...
let me start...
