Apple Macbook Air 13 A1496( 820-00165-a) bios
    Re: Apple Macbook Air 13 A1496( 820-00165-a) bios
    Originally posted by hoaca388 View Post
    So your problem is the password, not the ME region. Why not raise the issue in the first place?
    some members expect you to guess whats wrong rather than telling you
      that works thanks
        macbook air 2015 won't display after removing bios password
        it wasn't working with the original also
        820-00165-a
          It is already worked on, above file does not have a password. What did you use or did you erase using hex editor?
            Originally posted by mazorca View Post
            it is already worked on, above file does not have a password. What did you use or did you erase using hex editor?
            $svs
            this dump cleared
              clean icloud and efi password please thanks
                try..
                  hey bios masters
                  would need to have ME region cleaned
                  Works 100% but slow booting
                  Thanks in advance
                    Originally posted by magneh View Post
                    hey bios masters
                    Thanks in advance
                    try..
                      Originally posted by peste View Post
                      try..
                      thanks but still icloud lock
                        Do a PRAM reset,re-install the OS
                          Removed EFI password and iCloud and recalculated CRC, try and report back.
                          I don't provide help for people using CH341A and a clip.
                            Originally posted by hazem3636
                            I am working on a Apple MacBook Air A1466 820-00165-A logic board. The BIOS got corrupted or shorted because I have fan spin and all voltages are there, no chime or boot.
                            The BIOS probably needs ME cleanup and serial change to FVFYQ6F2J1WK. Please help
                            and attached version number and corrupted BIN file
                            Stop spamming in multiple threads.
                              so so sorry sir , but i saw much activity is this thread so i guess someone ll help me in here ! any way am sorry for misunderstanding , and thnaks for all Admin in this Forum it's anice job what are u doing here thanks alot , all the best
                                Best way to get what you need is to open a new thread, it's free.
                                  thanks for your advice Sir
                                    MacBook Air(2015)
                                    A1466 EMC 2925 820-00165-A
                                    S/N C1MQNB0JG941
                                    Region USA
                                    MY OLD BIOS WAS ERASED BY RESET SERVICE AND LEFT BLANK(AS IN NO BIOS AT ALL)...
                                    I paid to have bios reset, they could not fix it, so they refunded, then I purchased the cable from ebay, and tried to pull off bios to do the work myself but there wasn't one... bios is blank... Can anyone make me a new bios flash for this?
                                      Re: Apple Macbook Air A1496( 820-00165-A) bios
                                      SVP, Quelqu'un peut m'aider à supprimer le mot de passe, merci pour tous
                                      Please, can someone help me to remove the password, thanks for all
                                        in English please..
                                          in English please..
                                          thanks sir, good 100%
