need bios dump dell latitude 5420 (cpu 11th)
    Re: need bios dump dell latitude 5420 (cpu 11th)
    try
      Originally posted by amine23 View Post
      its not powerin at all
      Try clearn ME that file.
      Become a Badcaps supporter
      Thanks to all supporters.
        Anyone service tag H3QS3J3-8FC8 currently locked and need unlock admin pass?
          Post your backup BIN file and be sure to do three readings, all identical, start from scratch, use winhex editor to verify. Verify too after re-flashing by doing another reading and comparing to unlocked BIN. I now it seems tedious, but takes about 5 or more minutes and might save you hours of headaches. Also helps to practice if you are going to do this for a living.
            The device has a very long warranty, please contact DELL support.
              Hello hoaca338 it dosnt work clean me my backup need repair
                thank you for your help bro
                  If with the original file (the locked file) the device does not work, then there is a very high chance that you have damaged some component on your motherboard yourself.
                    every thing is good i changes the bios winbond 25q256 now is turn on but the laptop show only diagnostic colors
                      Try testing the output through the HDMI port.
                        there is no external display and there is 6 codes white and 3 oranges it mean recovery bios is corrupte
                          hi bro aldopc this is my original dump in page 13
                            Hello bro
                            i have found the problem its an resistor removed by hot air i need to know the value of resistor
                              Originally posted by aldopc View Post
                              ready test
                              can u remove pass
                                trY
                                  Hello bro
                                  Hi Bro did you find the value of the resistor, I have an operating board to measure.
                                    not yet bro
                                      What do you required exactly
                                        after unlock my bios the laptop show diagnostic colors and 6 white codes and 3 orange
                                          good afternoon unlock please my bios is very necessary
