Gigabyte GTX 1070 - no Vcore, other voltages ok
    I have this Gigabyte GTX 1070 that have no Vcore, but other voltages are ok
    any hint? i add measurements
    Re: Gigabyte GTX 1070 - no Vcore, other voltages ok
    Board marking is V17081
    So if anyone have BV or schema i will be greatefull if u upload it and i will post it to BIOS/Schem thread
    Im missing EN signal to uP9511P
      I think you are losing the signal line of the main power control ic. It's also similar to the gtx 1660. I've had a few cases like that, even though I changed the main control ic, there was no vcore voltage. Fortunately, once I reflowed the gpu, the vcore voltage came back but for 5'. Then lost again. I think, there will be 1 way to the gpu, and from the gpu will generate a feedback command to turn on the power for the central power control ic to work!
      PC work for schemaltic:
      Mainboard: Gigabyte Z68XP-UD4
      CPU: I3-3240
      Ram: 16Gb
      Graphic Card: GTX 1050Ti zotac 4Gb Mini
      SSD: 120Gb
      HDD: 2Tb
        no one makes reflow. only amateurs
          from datasheet of uP9511p i see that EN pin must be put to ground
          i trace that "dualmosfet" but need to know it datasheet or type
            Do you have a boardviewer file for this type, i'm looking for some missing ic
              sry mate no BV or schema and i dont have card anymore
                same q521. b20p03. I checked with my board
