Xiaomi Redmibook Pro 14 2022 (Intel) BIOS password
    Hello!
    I've bought laptop yesterday and found out that BIOS is locked with password.
    While I'm in process of contacting shop maybe there is a way to reset it?
    I've made BIOS dump with FPTW64, found the S.u.p.e.r.etc but can't decode text
    Please help with decoding Or may be there is another way of resetting it?
    HEX code: D2 76 FB 56 FA BD 95 45 5C 71 93 65 43 80 15 60 4E FC E0 51 0E 12 25 B2 75 B3 5C E6 5E 83
    BIOS dump is attached
    Re: Xiaomi Redmibook Pro 14 2022 (Intel) BIOS password
    Password was 0000
      Hi Yshlu!
      I'm have the same problem
      I have xiaomi redmibook pro 14 SN32922 on 11th Gen Intel(R) Core(TM) i5-11300H
      I'm try to backup bios via FPTW64 but it has an error - "Error 2: Failure. Unexpected error occurred"
      can you attache your FTPW64?
        Hello viacheslav.shostak!
        I'll try to find when come home this evening.
        Meanwhile please try the latest version of FPTW64. I've got the same error when used old version of FPTW64 but when I've doownloaded v16 it worked fine
          Hi
          I've been extracted bios dump by FPTW64 v15 (attached), open image by HxD editor and find password after 00 65 00 72 00 76 00 69 00 73 00 6F 00 72 00 50.
          As i see it must be "0RjgttR56" (pass in attached), but it wrong. This pass is not valid.
          The second way to extract bios backup is native utility from xiaomi to flash bios - "H2OFFT-SX64 backup.bin -g". I find this in C:\Users\{myusername}\AppData\Local\Temp\7zSB75C.tmp after extraction RMATG4B1P0F0F - latest available to loading bios version.
          But in those extracted backup password is also "0RjgttR56"
          Now i'm stuck.
          I don't know what to do next
          can someone help me?
            Upload your bios
              here it is
                Originally posted by viacheslav.shostak View Post
                here it is
                Try.
                ".0RjgttR56"
                  Thanks, but it's also wrong.
                  I've tried this before.
                    do you use upper and lower case letters, how is the password ??
                    "0RjgttR56" and the first is zero, not "o" of course
                      Yes, of course
                      I have tried both methods through "Caps lock" and through "Shift" (left or right side also changed, suddenly one does not work)"
                      And that there is zero "0" I also understood, I watched the translation from Hex to ASCII
                      that's why I'm confused
                        the last thing I haven't tried is an external keyboard
                        but I don't have it yet
                          Can there be two passwords? One from a simple entry into the bios and the second from the superuser
                            Yes, of course
                            Faced the same problem. Can you help? Here is the bios dump
                              threw off
                                threw off
                                Sorry, I've dropped it now.
                                  i am getting the same issue
                                    Originally posted by Yshlu View Post
                                    Password was 0000
                                    How did you get the 0000 value?
                                      please help me with the bios password
