MacBook Air A1465 820-3435-B
    Re: a1465 bios password
    here you go
    Im Back... sort of...
      Re: Can someone remove the EFI password on this dump Model A1465 EMC2924 TIA!
      Originally posted by Djosla View Post
      Try this dump I`ve rebuild for you and post results...if doesn`t work, post the motherboard code and i will try to provide valid dump for you...
      I will try this and post the result later. Thanks for helping me.
        It works like a charm.....two thumbs ups sir. Again thank you very much!
            I need firmware Macbook a1645, EMC 2631 because it is corrupt
            Please Help Me thank you
              Hi always upload original bio even if not working.
              techman1025
                Have fimware lock can help anybody?????
                  any body can unlock firmware please?????
                    I'm away will help you when I return
                    Techman1025
                      Registered mostly to download the dump and to thank you.
                      Be well.
                        Remove password from this file plz
                          Hello to all electronic engineers!
                          Please, help. I need a clean factory firmware for MacBook Air 1465 (2015) i5 1.6 4gb that will work without a serial number and in any region.
                          Is it possible? thanks in advance)
                            Regards
                              Re: MacBook Air A1465 820-3435-B
                              looking for clean bios for 2013 MacBook air 820-3435-b emc 2631
                              the original bios chip has been destroyed from liquid damage and is not readable
                              if anyone can help and upload a stock bios bin I have blank bios chips just need a good bin file
                              its a 2013
                              I also am looking for bin file for 2015 820-00164-a that IS MISSING biso chip
                              thanks
                                Macbook Air a1465 bios password pls
                                Please remove the password.
                                  Re: Macbook Air a1465 bios password pls
                                  try this
                                    Air A1465 Password efi remove help
                                    thanks to all
                                      It works
                                      Thanks!
                                        Re: Air A1465 Password efi remove help
                                        here you go
                                        do smc reset also
                                          Me to looking 820-3435-b 2018 or 2019 bios dump
