Hi all
i have an HP power supply PS-4321 connected in series with bulb.
Series lamp is blinking when i short green wire and ground.
Voltage on mail capacitor is fluctuating.
i changed all capacitor but still the same.
i checked for short NO SHORT.
i looks like power supply is restarting that is why series lamp is flashing.
without power i do get correct voltage on main capacitor NO FLUCTUATION but i am missing 6v on a smd capacitor that is connected directly on ic 6802.
i also changed ic 6802.
there are 3 optocoupler and the middle one on high side i should get 17v but i get a little voltage.
on secondary side i do have the 5v and aux 12v.
if i disconnect the side side of middle optocoupler and install diode, negative to ground the series light bulb is not flashing and voltage on mail capacitor is ok
can someone help!
can someone help!
