PS4 pro PSU ADP-300CR shuts down when turning on 12V
    I would like to ask for your help to troubleshoot a faulty PS4 pro power supply
    I have a st_by voltage ane when i try to power on 12v line PSU shuts off
    i measure lot of components but i don't fins faulty piece ,
    when i try to power on 12v line voltage increasing to ~420v so it looks like PFC was working,
    Now i have no idea what i can do more to fix it and i will be very helpfully to help me in this case.
    Re: PS4 pro PSU ADP-300CR shuts down when turning on 12V
    Need some pictures of the circuit boards in this device
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Rather, the problem is in the set-top box itself, if you manually start it and 12 v appear, if there is a problem with the set-top box, then it blocks these 12v.
        am sending the board photos
          any ideas ?
