Can someone identify 5v pwm regulator, (VRP5V0A) from attached photo?
The motherboard is an Inventec CHICLET 6050A2637901-MB-A02 (UMA)
It has some minor?? changes/differences seeing the schematic.
The schematic says that 5 volts regulator is the well known TPS51225, but on the motherboard 5 and 3 volts regulators are two independent chips. ( not a TPS51225 dual pwm regulator)
Problem with this mobo is that 5 volts are present only for 3 seconds an then goes to zero.
3.3 volts are present all the time.
Please help, I can't find any datasheet for chip U6150.
Thanks in advance.
Thanks in advance.
